sergio Posted March 20, 2011 Share Posted March 20, 2011 If you can help thank you serge I am looking for those parts ,my datsun is a 1977 280z,and my oil pan leaks even after changing the gasket at the Nissan dealership here in Tucson Az,and i was told that there are no longer avialiable..Does any one as a picture of those parts so i may go to the junk yard and know what to remove, or were i could buy some . thank you for helping From the Datsun / Nissan Parts Microfiche: 11124-R1000..............Reinforcement - Oil Pan (This piece goes around the rear of the engine, and along the passenger side of the engine. 11124-P6500..............Reinforcement - Oil Pan 11123-N3300.............Reinforcement with Heat S/Plate (This piece goes along the driver side of the engine near the Exhaust Downpipe) 11123-N4200.............Reinforcement with Heat S/Plate The Datsun / Nissan Mircofiche does not specify a change over date from the first part numbers to the second. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted March 21, 2011 Share Posted March 21, 2011 These are basically strips of 1/8" thick steel with holes drilled to match the holes in the oil pan. 11123-N3300 has a bit of sheet metal that folds up to protect the gasket from the exhaust down tube. Someone here will certainly have these bits laying around. I may even have them but would have to dig deep in parts bins. I'll try to get photos of my engine on the stand with these installed. The bigger problem is the lip of the oil pan being distorted from over-torquing the retaining bolts. You need to use a small hammer and flat dolly to smooth and flatten the lip at the holes to match the surface between those holes. Some decent sealant and a stock gasket will seal it right up. I usually use Permatex Ultra Gray but have also used Permatex 'aviation' sealant (#33 I think) or 'Right Stuff' sealant with great success. The secret is not overtightening the hardware. It may just be me but I never use the blue, orange or red silicone as it always seems to do a poor job by comparison. Quote Link to comment Share on other sites More sharing options...
jellobob Posted March 21, 2011 Share Posted March 21, 2011 (edited) If you are having problems sealing the oil pan Nissan makes a composite Competition Oil pan gasket (motorsport sells it ) It is far superior to the cork gasket but by all means use the reinforcement strips they even out the clamping force of the bolts on the pan . Also check that the pan has not been over tightened and that the bolt holes are flat not cone shaped or pointed toward the block . A tap on each with a ball peen hammer is usually all that is needed to level them .If you need the reinforcing strips i have a spare set they would be $10 plus shipping from 07055 Edited March 21, 2011 by jellobob Quote Link to comment Share on other sites More sharing options...
ZUL8TR Posted March 21, 2011 Share Posted March 21, 2011 I think I have a set, let me dig for you. Quote Link to comment Share on other sites More sharing options...
