Settings for 81zxt CAS
PITA_Z
I'm having trouble understanding how exactly I should have have my settings in TunerStudio for using the 81zxt CAS.
I have done as Tony D has done with his with CAS plate and rotated it 72*, but past that, I don't really know what to be
doing.
Here are my current Ignition settings (MSII, latest 3.1.0 extra code)
I thought I should be using toothed wheel, but then the Trigger Wizard under tools & Trigger Offset are disabled..
I've read & read a lot, but still taking a while for all this to sink in.
Edited by PITA_Z
I'm getting no response at all from the composite/teeth loggers in TunerStudio while cranking.
I tested the wires as they should be according to moby's info for an 83zxt CAS.
I hope one of you can tell me what settings to be using on the Ignition Options page, as it's probably wrong.
Dizzy side ------------ Harness Side
Red (12v) B/W
White (MS trigger) G/B
Green (not used) G/Y
Black (gnd) Black
I got (checking just on MS side connector):
Battery voltage on Red-B/W
4.2V on White-G/B (with 1k pullup)
& connection to ground on Black-Black
Can someone tell me where to be looking next to get the CAS reading properly?
Meanwhile I'll continue reading through the manuals.
Thanks.
Edit:
I was fiddling around with the connector between the CAS & MS wires and the fuel pump was coming on & off.
FP wasn't coming on normally when I had it connected & turned the key to power up MS, so I guess I just have a
bad connection there.
Edited by PITA_Z
You need to use Basic Trigger, and the Trigger Angle / Offset needs to be adjusted so the spark timing you see with a timing light matches what you see in the tuning software. (The correct number will depend on how the distributor has been adjusted.) Toothed Wheel is only used when you have a missing tooth type wheel, or two separate trigger wheels working together. Basic Trigger is what you use for six equally spaced pulses.
