ZG flare offsets
What kind of offset do i need running a 9'' rear tired with flares to fill them out?
The real question should be what backspacing do I need on a 9 inch wheel to make sure it clears my suspension. Also It has been covered a lot and on different setups as well. Build your car the right way and aesthetics will follow. Also you can't fill a ZG flare out too much on a lowered car without running stretched tires which is a problem on its own.
