Help with MSI Extra
Kali
So ive finally gona ahead and gotten MS now the more i try to set up the settings the more i get confused. Currently trying to run a MSI Extra Ive done what the forums said and read, read the mega manual. Seems like i get tid bits here an there but i still need help. So if anyones willing id really appreciate it. Emails, PM's, one on one consults(I live in Ft Lewis, WA). Here is my current setup:
Block:
* F54 L28et turbo block
* JE Forged Pistons and rings 89mm
* Mechart A-Beam Stainless Steel rods
* ARP Rod Bolts
* Diesel Maxima Crank
* ARP Head studs
* SCE 2mm Solid Copper head gasket with sealing rings
* Nismo single groove dampener w/ Nismo front crank bolt
* 83 280zx turbo oil pan
Head:
* P90 Head off 82 ZX turbo
* Schnider Cam Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280.
* Schnider matching dual valve springs, retainers, lash pads, and rocker arms
* Ported polished
* 5 angle valve job
* Resurfaced and decked combustion chamber and intake/exhaust side
* N42 non-egr intake manifold
* 420cc injectors
* JSK Fuel rail w/ Autometer pressure gauge
* T3/T4 Turbo
* 2.5" exhaust
* Z32 MAF
* 83 280zx dizzy
* MSD 6A
* 2.5" thick innercooler
* 2.5" innercooler piping
* MSA BOV
* Walbro 255lph
Update ive used the wiring diagram posted here http://forums.hybridz.org/index.php/topic/69077-msd-ignition-megasquirt-wiring/
and i have also used the setting posted here http://forums.hybridz.org/index.php/topic/47394-msns-extra024s9-settings-in-jpeg-format/
I havent gotten her started yet. I made a few mistakes in the settings. 1 FIDLE FUNCTION was set tospark A output. 2 LED17 was set to squirt. If you didnt notice i am going with a MSD ignition system and not the HEI, for spark advance. Thanks for reading, i will post anyother updates.
