82 L28ET lean out top end issue
  • Please log in to reply
22 replies to this topic
#21 stupid_fast
stupid_fast
    Moving Up
  • Members
  • PipPip
  • 35 posts
  • LocationNorth SF bay area, California
Posted 14 June 2015 - 09:09 PM
It was a bad ground.
Verifying the fix.
/thread
83 ZX NA->L28ET
#22 aarang
aarang
    Member
  • Members
  • PipPipPipPip
  • 373 posts
  • LocationCamas, WA
Posted 04 August 2015 - 03:15 PM
Just wondering what ground you found bad and if indeed it is fixed?
280zx-t in progress....
#23 stupid_fast
stupid_fast
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 2 weeks ago
Sorry I hadn't checked this thread in a while.
@mods, Necro post reason: found the real solution.
Turns out I was troubleshooting multiple issues with similar effects.
The issue I corrected in 2015 was a bad negative battery terminal, the bolt was tight but it was loose I could wiggle it around.
I've been rebuilding the drive train on my car over the past year, just got it running and the same issue came back.
I put on a fuel injection tester & monitored the fuel pressure while driving, it was dipping to around 20psi when the issue occurred.
The cause turned out to be a clogged filter screen at the fuel pump!!
I feel a bit silly after all that diagnostic work to find such a simple solution, but at least I verified the rest of my setup and learned something.
The motor is running very nicely now, after manually re-calibrating the AFM for proper fuel flow.
Edited by stupid_fast, 2 weeks ago.
83 ZX NA->L28ET
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
