LT1 into a Z32 + more
  • Please log in to reply
44 replies to this topic
#21 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
  • LocationJacksonville, FL
Posted 29 March 2012 - 02:46 AM
Just a few more pictures. I finished wrapping the harness and a few other odds and ends. Enjoy!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Edited by dts300z, 29 March 2012 - 02:48 AM.
#22 garvice
garvice
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 696 posts
  • LocationBrisbane, Au
Posted 30 March 2012 - 01:55 AM
Looking great!
Is the aluminised tape to direct air flow?
#23 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 30 March 2012 - 02:45 AM
Thanks! Yes Sir! I've been working on trying to keep it cool at highway speeds (stays right at 172 degrees at idle). I think it's about whipped. I've finally created the low pressure zone in the engine compartment to help force the air through the radiator. Time to find a more permanent solution.
#24 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 08 August 2012 - 06:14 AM
It's looks like I'm going to retire the LT1. Time for an LSx swap.
Torched number 7 during a full throttle blast. Coolant hose blew, coolant temps went up and that was all she wrote. Needless to say we are starting over again lol. Not such good luck with the ole LT1.
Posted Image
Posted Image
#25 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 10 August 2012 - 03:02 PM
What the UPS man left for me... woot
Conversion flexplate
Posted Image
LS6 valve springs
Posted Image
Rod bolts
Posted Image
Trans dapt motor mounts
Posted Image
A lil intake fo da squre bore.
Posted Image
On the way... enough to get things rolling.
#26 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 15 August 2012 - 03:51 PM
$280 at LKQ... good price IMO
Posted Image
Posted Image
Posted Image
Posted Image
#27 v8dats
v8dats
    Member
  • Members
  • PipPipPipPipPipPip
  • 1058 posts
  • LocationPinellas county, Fl
Posted 16 August 2012 - 01:06 PM
Bummer about the lt1. love the z32 platform. good luck with the new combo. making power with it should be easy!
TO Z OR NOT TO Z...
#28 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 17 August 2012 - 05:17 AM
Thanks! Yea it was a bummer but I'm actually a little more excited about the new swap. Should have a lot more potential. I think I might have to modify the firewall a bit more. Good excuse to spend a little more time on it to make it cleaner.
Edited by dts300z, 17 August 2012 - 05:18 AM.
#29 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 18 August 2012 - 04:54 AM
A little more progress. This thing is a bit taller than the LT1. Looks like I'm going to have to think about going EFI again. The damn oil pan is against the rack and the carb is sticking through the hood. The carb was about 2-3" lower with the LT1. Decisions decisions...
Oh and I had to hack into the firewall again lol.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#30 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 25 August 2012 - 01:40 PM
Makin some mo progress! Got the mounts welded up and everything nice and centered. Need to do a bit of modification to the oil pan to get it to fit. The sump is super low on the truck pan and it needs to be thinned out a bit where it crosses the rack.
Had the wire speed up a little too high and got a bit of a booger weld but I really don't give a **** it'll hold just fine lol.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#31 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 05 November 2012 - 03:53 AM
Made some more progress this weekend. Still have to finish welding up the tunnel and cutting the excess material off. Might not need much bondo when this one gets done.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#32 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 09 November 2012 - 10:06 AM
More progress!! Got it all welded up. A little body filler and paint and were ready to rock.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#33 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 18 November 2012 - 11:20 AM
More progress!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#34 garvice
garvice
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 696 posts
Posted 19 November 2012 - 02:27 AM
Looking good, what do you use to bend/shape the tunnel?
#35 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 19 November 2012 - 05:00 AM
I actually just slowly work it into place.
I made a template with cardboard and then gave myself an extra inch or so all the way around the template (except for at the top). I started at the top, the only place I didn't add additional metal and started taching it. I welded everything from the inside except for the top. I had to tach it into place on the outside while I was forcing the metal into the tunnel. Easier said then done. Where the metal met the existing tunnel I had to use a bit of pursuasion as I tached it in. It didn't take very long. Took more time to grind all the excess metal down and smooth it out.
#36 garvice
garvice
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 696 posts
Posted 20 November 2012 - 12:37 AM
Thanks for the explanation.
#37 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 24 January 2013 - 04:12 AM
Alrighty finally making some progress. Drop the engine in and started mocking up the fuel system and turbo hot side.
#38 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 28 January 2013 - 04:28 AM
Got some more finished up over the weekend.
#39 1point3liter
1point3liter
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 31 January 2013 - 06:48 PM
:ph34r:
#40 dts300z
dts300z
    Member
  • Members
  • PipPipPipPip
  • 312 posts
Posted 04 February 2013 - 08:24 AM
lol
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
