akaryrye
Everything posted by akaryrye
Perhaps that would be better, but I am going to stick with what I have since I have already done the portwork and they should flow better than stock gt40 heads. I might have been better off, however, to just buy an entire explorer motor and swap that in Oh well, Im sure this setup will be plenty fast for me and will work just fine. As for the block, the cylinder bores are straight, no cracks, and the decks are flat. The crank, rods, and pistons are in good condition, so I am only sending the heads to the machine shop. The rebuild will probably come out to around $500, including a valve job, bronze guides, and a replacement flywheel (old one has hairline cracks). I am yet unsure if any new hardware is needed, and that would add to the cost as well. I am not shooting for the moon with this car, 300whp is what I am hoping for and I see no reason why this motor wont be able to do that or more. The hardest part for me right now is deciding what parts are the best for the money as far as bearings, gaskets, and rings. Also not sure what flywheel to get as I dont know if the engine has been converted to a 28oz imbalance or retains the original 50oz. The markings on the crank pulley are very hard to make out, but the flywheel seems to be from a 28oz imbalance engine. This doesn't mean it is necessarily matched to the pulley though because the car was converted to manual transmission after the original engine build (in the youtube videos, the car rocks an automatic). lol, sorry for all the ranting ...
I just wanted to check in to let you guys know I have not given up on my project, I am in fact still working on it I pulled the motor a week ago to rebuild it and while it was not everything it was claimed to be, it did have some upgrades. The heads appear to be completely stock, no porting was done as was claimed. I did, however, find .30 over forged pistons and a "stage 1" cam from a company called Cam Dynamics which was apparantly bought out in the late 70's and I cannot get any information other than that the lift at the lobe is .464 if i remember correctly. There was a double roller timing set as well, and the crankshaft seems to have been balanced at some point. Further, all rod/piston assemblies have matching weight at 3.2oz. I also found two cracked rings and a bent pushrod, which would explain the somewhat anemic performance. So, I am just now finishing up some port work on the heads which involved removing the vlave guide humps, opening up slightly and blending the bowls, gasket matching the intake, unshrouding the valves, and cc'ing the chambers to 56cc (up from 54cc). I havn't measured the deck height, but it looks like this setup will be around 9.5 - 9.7:1 compression ratio. I am taking my time and want this to be done right Sorry no pictures, I look forward to getting this thing running again soon, but it may be another month or so because beside rebuilding the motor, I will be stitch welding the engine bay, adding some reinforcement to the rails, and repainting.
Well, last weekend I finally got it off of the jackstands and ready to fire up. At this point I have rebuilt the exhaust, made a new tranny mount, redid the engine bay wiring by removing unnecessary wires and adding some new wire as well, and installed new gauges and sensors and a few other this and that sort of thing ... but when I went to start it, the engine backfired out the exhaust and caught the filter on fire I forgot to mark the distributor when I took it off, and I am eyeballing it from my pictures above. Shouldn't that be close enough? OTOH, it wasn't the easiest to start up as it was so maybe a little bit off means no start? A little help would be welcome Oh, also what should I set base timing to once I get it started? I have a 4 bolt v-belt pulley and I am not quite sure what the timing mark indicates. I suppose I could always find TDC with a rod of some sort in the plug hole.
it sounded cool i guess, if not a bit too loud. I am finally almost done with the new exhaust and headers and I hope it will sound a lot quieter though. I think some of the mean sound was created by massive exhaust leaks. Anyway, sorry I have been slacking on pictures, but I have been working. I removed all unnecessary engine bay wiring now, installed all new gauges (oil temp, pressure, clt temp) and mounted the tach in the factory location. I got the interior lights working, wired the headlights through relays and beefy wires, and cleaned up the engine bay by shortening the heater hose, fuel lines, etc. Finished the exhaust, aside from a header primary tube which I am modifying to get steering rack clearance.
swap the mounts for truck mounts and you will be good to go
Been working on the car some more. The exhaust was a basket case, so I redid it with patriot truck hugger headers and 2.5" piping and mandrel bends (sorry no pics because I was in the zone). Exhaust pics show what came on the car complete with headers cracked in multiple locations, terrible welds, and sections left unwelded which left gaping holes for exhaust to leak out. This necessitated a new transmission mount with reliefs for the exhaust (again no pics yet). BTW, firesaw is a baddass tool. Some wiring work as well with relays for the headlights also. Anyway the pictures I took are below:
http://lainefamily.com/240Z_V8_Conversion.htm everything you need to swap it in is on that website. There are even blueprints of the fabricated pictures with measurements and everything. solid mounting design and the transmission mount is not too shabby either.
its a flowmaster
Well I spent some time working on the car this past weekend. Most of my work involved compression testing the motor, continuing to strip the interior down to the metal, and electrical work. Bad news is that the motor has low compression in two cylinders and wet compression test tells me it is the rings. So, looks like I will be doing a rebuild. Good news is that I discovered the motor has 4v heads. I like the idea of having a fresh motor and knowing exactly what parts are in there anyway. Spring break is coming up and during that time, I want to rewire the car (the extent to which is yet undetermined), finish stripping the paint off of the metal in preparation for a sealing primer, and redo the exhaust with patriot shorties and 2.5" piping. Dont know if it is all possible, but I will be spending lots of time on it. A megasquirt efi system is also on the mind. Stripping interior more, next week I will be armed with dry ice and aircraft stripper. New window regulators on both sides, now they go up and down! hmm, signal converter + sell autometer or autometer tach that doesnt match but is more precise ... the cheapskate in me says keep em stock, i dunno. Rats nest: What the hell are those gold boxes on the drivers side wheel well? Ok ... seriously wtf man? that is not how you wire anything ever ... EVER! Wiring harness unbundled, more garbage. Here is how I left her until next weekend. This is my friends shortened subaru legacy lol. It runs beautifully, but it does not have a radiator hooked up right now so it only gets run for short periods of time. It was built to be basically a 4wd sandrail, but now it just sits and collects rust. This day, it was used to tow a chevy nova and an rx7 which did not run into the back yard. (pics are not me btw)
Ok the entire exhaust is custom and it is going to one muffler. I don't know what muffler it is or the piping size but Ill try to take a look when I get it up on a jack next. Ill see if i have time this weekend, but no guarantee because Ive got bigger fish to fry with sorting this car out.
Oh totally, I know its bull. I am pretty sure it has a cam and ported heads. I think it either needs new rings or a valve seat since there's quite a bit of blowby coming out of the breathers so i may be pulling it out sometime and find out what work was actually done to the motor. Gotta do a leakdown and figure out what's going on.
did you notice the posting date? this was four and a half years ago
Just found some youtube videos of the car. Claims it is a 500hp build ... good lord this thing is gonna make me crap my pants when i finally open up the throttle for real. I need to do a compression test on this thing. http://www.youtube.com/user/santacruz95949#p/a/u/2/JbMeS4npBa0 http://www.youtube.com/user/santacruz95949#p/a/u/1/bKeQxJ3_1mk http://www.youtube.com/user/santacruz95949#p/a/u/0/jVEOD_qE6Gg
LOL, crazy! I just bought this car from a guy in Reno for $2200. I am positive its the same because of the oil filter relocation, the custom radiator, the front lip, the tachometer, the rocker covers, the exhaust tip, and other subtle cues. Pretty wild to see a video of it. I need to get in touch with the guy.
Well, I Picked the car up for $2200 and drove it home a few days ago. As purchased, There were a few issues. Some ghetto wiring, crappy paint, exhaust rattling against the frame, passenger seat trashed, and some of the gauges arent working, including the speedometer and coolant gauge (yes i drove it home that way ). Luckily it was a cold night and a huge radiator sits where the stock one used to be ... heater was full blast the entire time as well. Even worse, the check valve for the brakes was installed the wrong way, making braking a scary thing until I figured out how hard i needed to push to get it to stop. Its got some issues for sure, but it did make the 200 mile trip home, and with around a third of the tank left. Supposedly the motor is a 302 with a block from a 74 and heads from a 68. It has an MSD ignition which I know very little about and an Edelbrock 1407 Carburetor. There is a very nice custom radiator setup with an electric fan. Suspension is definitely aftermarket as the car rides fairly low and I can see an aftermarket sway in the front. Tires are fairly new and there are cragers in the back which look sweet. My plans for the car are to eventually make it a streetable race car. Something I can take to the track or autocross on the weekends and drive to work if I want to. My short term goals are to strip the interior down to the metal, fix any rust, and lay down some POR 15. So far, I have found some rust, but I don't think any has gone all the way through yet. Getting the carbs in tune, Cleaning up the electronics and getting working gauges is also high up on the list. Seats, roll bar + door bars, and better brakes will come next. Beyond that ... flares and wide rubber, better camber/caster/toe adjustability? One thing at a time. Anyway, some pictures of the car that I have taken so far. Exterior Pictures (note the **** wing is removed and will be on craigslist) Interior Pics, taken post-gutting. Most panels are present, but I probably wont reinstall many. I like the look of the exposed shock towers also. Engine pictures
FSB mounting points/ Bellhousing Bolt Pattern
akaryrye replied to akaryrye's topic in Ford V8Z Tech Board
well I ended up buying the car. Turns out it is a 302 windsor with edelbrock manifold and carb. Spent the day ripping out the interior and removing the sound deadening. There is some surface rust, but nothing too bad . Carb is tuned super rich also so gotta do some tuning, and since it is a windsor, an efi swap shouldn't be a big deal using mustang parts. There are some other issues with wiring and tune as well, but they shouldnt be too difficult to take care of. -
Thanks, I am pretty sure you are right. Another option I suppose is an EFI conversion, which would be cool too ... perhaps even a better option. Anyway thanks for helping me out and Ill post pictures up if i end up getting the car. -
Ok, this is a simple question but I have literally spent two hours researching and have not found a definitive answer. Hopefully someone can answer because I am looking at purchasing a 240z with a 351 cleveland engine installed and want to know what other motors / transmissions I will be able to swap in with the existing mounts and driveshaft? Ideally I would like to swap in a more modern and efficient EFI motor from late model fords. So have the engine and transmission mounts changed over the years? Has the transmission bolt pattern changed? and has the output shaft from the transmission changed? Thanks
