forzfun
Everything posted by forzfun
  1. If you want to protect your exhaust system call us. We have many different coatings that can handle the temp from chrome-like to natural looking. Price for the coating headers range from $190 to $350 depending on type and coating being done. We are in Cleveland, OH and can be reached at 440-735-2628, Powder and Performance Coatings, or http://www.powderguys.com
  2. The valve on the megasquirt system also positively shuts down the water injection system. It eliminates lag on shut down if you have a long line between the holding tank and siphoning depending where the injector is located. I like the suggestion on locating the IAT sensor before the injector, which will be in front of the TB. I'm putting an air/water intercooler that directly bolt in where the J tube is after the turbo in the 81 to 83 280zxt. I found it on E bay last year and it was desinged for that engine. Very clean and very easy. Planning on using the water injection if water temp get too high in intercooler on long runs. My goal is to safely boost to 15 lbs. using regular 91 octane gas. I run 12 lbs. now on a air to air intercooler with no problem on a 83 zxt on 91 octane. Also on that aquamist fast acting valve, checked the price and it's over $200. Found a 12 volt 1/4 inch direct acting diaphram valve that should work for around $60. 81zxt- daily driver, except in snow. 81zxt- project car-imsa body-ms- intercooler-water injection 83zxt- project car- same as above for my son 83zxt 2+2- showcar "It's not for the speed:burnout:, it's FORZFUN:lmao: !!"
