EnthZ
Everything posted by EnthZ
  1. Very late response but I have the car running and I am pretty much missing the window to be a DD. I measured the distance and I am in need of the 4 7/8 regulator for the driver side. It was approximately 5 inches from hole to hole.
  2. I have a 72 240z. The driver side door was badly damaged when i purchased the car so I bought a new one off ebay figuring all the internals swap out. It was listed as "Datsun 240Z LH Ca. Door 69 70 71 72 73 MINT SUPER NICE!". I didn't notice they looked different until I had it bolted on the car and realized my regulator didn't line up or fit whatsoever. I will get those measurements today after work.
  3. From the album: Misc
  4. EnthZ
    Misc
  5. From the album: Misc
  6. Would you mind sending me a picture? Thanks
  7. The door I have is exactly like this one. From what I understand, this is a 260z door. As you can see there is no bump for the spring. I will measure the distance tomorrow morning between holes. I believe this is what the regulator should look like. This has given me such a headache that I am also thinking about selling this door and finding a nice solid 240z door if I cant find a regulator.
  8. I am looking for the Window Regulator with the spring facing out towards the car. I purchased a bare door not knowing the difference and am now stuck with no ability to put a window in the door. I appreciate it. Thanks.
  9. I ordered a set of these to install soon. They have an instruction manual incase you didnt receive one http://cdn.shopify.com/s/files/1/0179/5453/files/DL240z.pdf?460 Otherwise I can't really help you from across the country but good luck
  10. I am messaging that guy you mentioned from ebay "gira7777" Cause I have been looking for a correct Tall Stalk fender mirrors for a while. Yeah dice, dont feel bad.. most people dont notice the difference between the Short Stalk (510 OEM) vs Tall Stalk (240z) Mirrors. Most Z owners here use the short stalk and seem to like them plenty.
  11. Don't want them to pop out of fender on stock suspension without flares yet. Not sure if that offset would work perfectly or stick out.
  12. Ok, So just confirming it all to see If I can go this route You are running completely stock suspension and you have now 225/60/15 on 15x9 +0 All that is required is rolling/pulling all 4 fenders and then adding +5 or higher spacers to the front? Do you have any rubbing after this? Thanks
  13. Hah, sorry I didn't read your wanting to keep it NA comment on the first post. The rest of my post still stands though. Exhaust/Headers don't do much with this engine its about +/- 3HP from the dynos I have seen. Have to improve the engine and transmission and diff to get those speeds. If you are really up for it and have a knack for engines, or an experienced mechanic you have the option of boring out your L28 to 3.1L. Kits are sold from various places. Arizona Z Car / Motorsport Auto. I believe they run you around $3,200. Of course if you can located all the parts yourself be it junkyards or aftermarket, It should run you way less around $1300. And yeah of course if you just got the car, Change all the fluids, Check the sparks and such to give the car a tuneup if needed. Switch out those Park bench bumpers for early style ones or FRP. Anywho its your car and your choices! Do what you want and have a good time doing it =).
  14. You are better off Selling your engine and getting L28ET if you can find an honest trustworthy mechanic to swap for you unless you are eager to learn and can do it with manual and some time. The Turbo Variant of your engine will come off of a 280zx Turbo'd obviously. If what you are after is faster 0-60 you would also be good to find the transmission from the same car 81-83 5-speed. Differential as well. So to sum up. L28ET (you can usually find for about 600 just be patient and search) 280zx 5-speed tran (could find bundled with engine or might have to find a used one somewhere) R200 out of 280zx or if you really want accel 4.11 diff out of the 200SX turbo The most important advice I can give you though is be patient. You want to go out there and get everything done quick but you are young and have lots of free time on your side. Do everything with research and patience. Wait for the right deals at the right times. Don't cheap out on parts.
  15. Yeah I actually went through this struggle couple days ago, That was the Air dam I wanted and I could not find it. Decided It was that one and the camera with paint made it look different than it really was.
  16. EnthZ
    240z L24 Engine Bay
    240z L24 Engine Bay
