md77
Everything posted by md77
  1. The key does come out of the ignition, in the on position, and the normal position. I dont remember if it did this before, last time I drove the car regularly was 3 yrs ago when I left for college. so it might be either one. How much is the ignition switch cost. I will look at the underside of the column when I get home ad see what I can do. Thanks MD
  2. There is a problem with the ignition switch that I need your help with. If you turn the key to the start position, usually nothing happens, except a "click" coming from the fuse box. You have wiggle the key for a little while to engage the starter to start the car. It seems to be connection problem, except the fact the car acts like the power is being diverted to the starter, plus there is the afore metioned clicking sound, everything goes off like normal, until you turn the key back to "ON, regardless if the car is running or not. It is getting worse, today I had to aggressively wiggle the key for 10 min until, the car started. It is easier to roll my car down my driveway and pop the clutch, but I am afraid of damage of prolonged use of this method and there are not many hills in Albuquerque to roll down, except at my house, so I try to avoid driving the car that requires me to restart the car before I return home, and the car about to run out of gas. Thanks Marshall
