gene_w
Everything posted by gene_w
You might check to see which way that engine rotates. I've known of a number of boat engines, including 351's that run in reverse from what a normal car engine does. If it runs in reverse, then you'll need to change that. I'm not sure what all that involves, but at least a cam for sure. Gene
No problem, but it will probably be next week before I can get out there to do it. Pretty busy until then and going out of town for the weekend. Gene
The front sump on my oil pan is behind the steering rack. Unfortunately, though, the sump was hitting the crossmember and would have either required the crossmember or the sump to be modified. Modifying the mount instead allowed me to slide the engine back a little bit more to where I think the sump will just clear behind the crossmember. I may have to cut a notch out of the back of the factory crossmember to gain a little clearance, but I'm not sure at this point. All I do know is that the engine's not going to go any further back. There's only about 1/8" between the head and the firewall! Gene
We talked a little bit the other day via AIM, so you probably already know my answer, but I'll post it here for the record. I've got alsil's motor mount on my Z with the 351W(not running yet). It is not a direct bolt-in fit. The front sump of the oil-pan will hit the Z's crossmember. Either the oil pan or the crossmember needs to be modified. I've modified my motor mount to lower the engine 1", which allowed me to slide the engine a little further back, and looks like it will allow the front sump to just clear. Gene
Actually, I already had one of those. It wouldn't help matters any. The front part of the pan came down almost as far as the fox-body pan that I have now. The problem is that the oil pump is up there, so the sump can only be shaved down so far. That pan also wouldn't work with Alsil's motor mount setup. The pan was hitting the crossmember part of the mount.
Hey ford guys, need some help here! Bad lifters in 5.0
gene_w replied to labrat's topic in Ford V8Z Tech Board
I'm not exactly sure what would cause the roller bearings to fail in the lifters. That is very strange. Hopefully any shrapnul caused by the bearings ended up in the oil filter. If I were you, I'd drop a couple new lifters in (maybe even the whole set just in case) and a cheap cam. I hear these are excellent cams, and cheap too! http://store.summitracing.com/product.asp?p=3789&searchtype=ecat You can get a set of used lifters for real cheap from swap meets or through ebay. Gene -
Does spacing down the crossmember have any adverse effects on the handling of the car? I know that most people are moving the inner pivot point for the lower control arms up to counteract the effects of lowering the car. Spacing down the crossmember might be just the ticket for getting my oil pan to clear. When you say that your engine is mounted at a 2.5" angle, is that in relation to the ground or the frame rails? Thanks, Gene
You would be correct.
Are you using Alsil's mount or did you design your own? If it's custom, do you have any pictures? How far below the front crossmember is the oil pan? Thanks, Gene
Unfortunately, a 5L oil pan won't fit a 351W. The 351W has bigger mains than the 5L and so the rear of the pan has a bigger cutout in it. I assumed the front of the pan was the same, but apparently I was wrong! I see that my pan is very different from yours...wonder why in the world they would have designed the two pans different. Mine is a standard Ford pan from a Crown Vic. or something like that. Hmm...I wonder if a 5L oil pan front sump could be grafted in... I could have sworn that some other folks around here didn't have any trouble getting the 5.0 under the hood without any hood modifications. Do you have any pictures of how your modified hood looks? Thanks, Gene
How did you manage to get the engine far enough back to drop behind the crossmember? Mine is already back to where the bellhousing bolts hit the firewall. The only way to go back any more is to lower it down. Are you using Alsil's mount or a custom one? Do you happen to know if the front-sump oil pan you mentioned is that different from the dual-sump pans as far as clearance in front of the sump? I'd love to see pictures if you have them.
I'm thinking that's going to be my best option for hood clearance. This still won't solve my oil pan problem, but would fix my problem with the hood. I'm sure it will look noticeable to me, but hopefully you're right and nobody else will know the difference. I'm not sure how much I can modify the front sump, because that is where the oil pump is. It is driven off of the distributor, so that's why it's up there. When Ford came out with the Fox-body cars, they needed a rear sump, so they just made a dual sump pan. Only the rear sump is actually a sump. The front one is strictly for oil pump clearance. As far as I know, the oil pump isn't any different than the 5.0 unit, except for the bigger input shaft, so maybe I can cut/bend the front sump to clear. Anybody done this?
Shifter location shouldn't be too big an issue. If you get a bellhousing from a SN95 mustang ('94-'95), that sets the tranny back another inch or two. Be sure to get the transmission or at least the input shaft for the same year car because it is longer as well, to meet up with the clutch. Gene
I am having some minor, shall we say, issues cramming a 351W into my '75 280Z and was curious if any of you might have had the same problems and how you solved them. If you haven't done the same thing but were considering it, keep these issues in mind. First, some background information. As already mentioned, I'm putting a 351W into my 280Z. For mounting, I have one of Alsil's crossmembers. I plan to run EFI and would really like to fit everything under the hood without having to use a cowl/scoop. The plan is for the car to be one hell of a sleeper, and anything too obvious from the outside is a major problem. Actually fitting the engine in the car wasn't that much of a problem, since these ol' cars have pretty big engine bays: One problem that I did have, which apparently isn't an issue with a 5.0, was that the front oil pan sump hits the original crossmember. I guess the 351W has a deeper sump! (keep in mind that the front crossmember has been unbolted and lowered in this picture) As an attempted solution, I tried moving the engine back until the bellhousing bolts hit the firewall: Even with the engine back that far, the front sump still hits the front crossmember. Has anybody else had this problem? If so, how did you solve it? All suggestions are welcome. The other problem I'm having is trying to make sure the engine will fit under the stock hood. As mentioned earlier, I plan to run EFI. The upper intake manifold measures 5.75" at its tallest point. Unfortunately, I don't have quite that much space to spare: As you can see, there's only about 4" of clearance at this point. Shaving down the intake is not an option because it comes within less than 1/4" from the valve covers as it is. Smaller valve covers aren't much of an option because of the large roller rockers. I think that there may be a possibility of lowering the engine a bit more, but am not sure how low is safe. Here's what I see from under the car as it sits now: My question here is, how low can the engine go? I think that if I can lower the engine some more, the bellhousing bolts will clear the firewall and the engine can be moved far enough back to clear the front crossmember, but I'm not positive about that. Removing the engine or bellhousing in the future could be a real pain in the @ss if I went that route, though! Any thoughts/comments/suggestions are more than welcome. Thanks, Gene
Here's the page that I was thinking of: http://www.geocities.com/zgarage2001/borg.html
The biggest problem that I can think of off-hand is finding a clutch that will work. A bellhousing off of a Mustang should work to bolt it up to the new engine, but the input shaft is different between the Z and Mustang transmissions. Unfortunately, to change the input shaft, the entire transmission guts need to be swapped. There is a possibility that you might be able to find a clutch disk that will work with the Ford pressure plate, but I don't know off-hand what might work or if the input shaft is even the right length. I seem to recall reading some information on the problems with the swap somewhere on the net...can't find it offhand, though. Another issue to consider is that the old BW trannies aren't anywhere near as strong as the later ones found in the later Mustangs. The one in the old 280zx's is not a World-Class unit, and is rated at a much lower torque spec. If any real modifications have been made to the 5.0 engine, you risk blowing up the tranny in no time! Gene
As far as the firewall being 3" further forward, I can't see that as being much of an issue. I just dropped a 351W into my '75 and have roughly 1 foot(not measured, just eyeballed) between the very tip of the water pump pulley and the radiator. Even with 3" less, there would be plenty of room. I think the age, as you mentioned, is probably the biggest factor. One of the biggest issues for me is that my ol' '75 is old enough that I no longer need to have the sniffer test to pass inspection. (I live in Texas) That means basically no inspection of any emissions equipment, and the hood rarely even gets opened during an inspection. Another aspect of the age is that there simply aren't as many of the ZX's laying around otherwise dead. Many of them are stillin good, running condition and most people have a hard time tearing apart something that works.....fortunately, I'm not one of them! Gene
I can't speak for anyone else, but I haven't done it because I don't have a ZX. If someone's willing to donate one to a worthy cause, I'd definitely be sure to investigate! Matter of fact, I've got access to a car that would be more than willing to donate an organ or two... Good luck! Gene
best hydraulic clutch slave cylinder for 302/t5
gene_w replied to randy 77zt's topic in Ford V8Z Tech Board
Sorry to dig up an old post, but this one caught my attention. Do you have any pictures or sketches of how you mounted the pull-type wilwood slave cylinder on your T5 tranny? I am just about to the point of having to set up the clutch and am looking for solutions. Thanks, Gene -
External. The old 302's, 5.0's and all 351W's were all 28oz, and the newer 5.0HO's were all 50oz. Gene
Hey, Terry, you don't have any spare T5 parts laying around, do you? I recently got a hell of a deal on a couple T5s. Unfortunately it turned out to not be quite such a hell of a deal. One of the trannies is pretty much trash, but the other one seemed pretty decent. That is, until you look at it in good light. The roller bearings between the main and input shafts were toast and the heat from those ruined the input shaft, main shaft, 2nd gear, 3rd gear, and cluster gear. Pretty much the whole thing! I've got a good main shaft from the other tranny, but need the rest of the parts. Where can I get ahold of one of those hydraulic throwout bearings? A few people around here say that one doesn't exist for the T5 trannies, but obviously that isn't true! Thanks, Gene
I'm not sure where you're located or if you'd be willing to ship, but I"ve got a driver's side door glass from a '75 280z here in D/FW, Texas. Let me know if you're interested. Gene
I've been running my '69 Mustang on 89 octane for quite some time with no negative results as far as I can tell. It's got about 9.3:1 compression. Gene
