This is the current set up of my 260: 2-bolt 350 .030 over,Speed pro .100 dome hypereutectic pistons with 1/8" plasma moly rings, stock rods and crank with ARP 190,000psi. bolts,balanced bottom end, 8" factory balancer. top end: Holley 750 d.p. with stub stack and integrated cold air box fed by glass cowl hood, Holley Contender idle to 7200 intake, this manifold is great for a street driven car by the way, have ran a sportsman and an rpm but prefer the Contender due to its larger ports, Sportsman 64cc angle plug  heads with minor bowl work, custom ground Schneider hyd. roller cam: .480 .480  246 246 at .050" on a 108 center line installed straight up. (low lift for longevity on the street), Speed Pro lifters and pushrods, melling hi-volume oil pump, Aerospace Components electric water pump,Holley blue pump set at 7.5 psi, aluminum crank pulley to turn low mount alternator, MSD nascar distributor,6al box, timing computer w/2 degree retard at 6000 rpm controled by rpm activated switch, two step rev limiter  3000 and 7000 rpm (converter is too tight to use the 3000 off the line), MSD shift light set at 6000 rpm. Can  anyone tell that I am a firm believer in MSD's products? Turbo 350, tci 10" converter, 10 bolt chevy rear narrowed, Richmond 4.10s, Strange spool, Mosier axles, c-clip eliminators,and Red Line synthetic diff. lube. Amsoil synthetic engine oil and filter. 1 3/4"  tube full length block hugger headers with 9" collector ext. Best e.t. was on Exxon 108 leaded race gas, about 60 degree outside temp, 140 to 150 engine temp. Sorry if I bored anyone, but if anyone has questions about any other specs of the car let me know !
