Randy 80ZX
About Randy 80ZX
  • Birthday 10/29/1950
  • Gender
    Male
  • Location
    Iowa City,Iowa
Randy 80ZX's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. updated my other post with gas cap information as to why check valve changed The fuel tank vacuun relief valve part of the check valve , was relocated to the gas cap in 1982. 79-81 gas caps do not have vacuum relief built in them therefore the 3-way type fuel check valve. The 82-83 gas caps have vacuum relief valve added to them , therefore the newer check valve is only 2-way. This also implies 79-81ZX fuel caps will not work on 82-83 ZX
  2. Black Dragon has the part for $340.Phone (888-789-3746) way overpriced everywhere because of the pressed on bushed ends.
  3. Is there a specific year & model TPS that I can use?
  4. Thanks Dexter72 ....I started shoping for a Maxima or Altima TPS and discovered many different sizes and different configurations for connectors,priced anywhere from $25 -$95. Just knowing mine won"t work helps with the research to install a SDS system before I actually begin. THX Randy.
  5. Will it work, or what upgrade or modification will I need to do to make it work ? Thank you Randy
  6. Randy 80ZX
    1980ZX
    MSA Standard Wing
  7. Has anyone tried a Geneis aluminum radiator? http://www.genesisautoparts.com/all_aluminum_radiator-nissan-280zx-1980.htm
  8. I visited Arizona Z car in Phoenix in April and Dave said he was working on a aluminum radiator for ZX but the bottom outlet was slowing progress.
  9. Has anyone heard from Koyo about further development of the S130 aluminum radiator?
  10. I know what part you are looking for its under the plastic cover by the differential and the evaporative line from tank goes to it. Try Z Car Source of Arizona 623-581-9228. I've gotten hard to find parts from them. The fuel tank vacuun relief valve part of the check valve , was relocated to the gas cap in 1982. 79-81 gas caps do not have vacuum relief built in them therefore the 3-way type check valve. The 82-83 gas caps have vacuum relief in them, therefore 2-way check valve. This also implies 79-81ZX fuel caps will not work on 82-83 ZX
  11. http://forums.hybridz.org/showthread.php?t=113108&highlight=pillar+pods
  12. I used 2 Stinger fuseblocks, one holds 4 fuses and the other holds 2 fuses. Then mounted them on 1/8" aluminum plate that replaces the plastic cover over the horn relay and EFI relay. Google "Stinger fuseblock" a lot of audio supply have them.
