Not too sure if anyone can help me.  I am getting very close to finishing this project.  I haven't been here for a while since work and all but ran into this issue.  Well, its an lt1 going into a 240z with a 6 speed manual trans (t56).  Anyways, I got a new clutch pressure plate, flywheel just light resurfaced, and disc.  I went to put these new part on the motor and the flywheel was easy since there is a hole for a dowel alignment mark.  Disc went on facing right direction as I doubled tripled checked that.  Next is the pressure plate, I looked for alignment marks all over the place, none.  All the holes line up no matter how its turned.  Well, bolted it on, torque to 20lbs + 30* turn, all is well pressure plate on solid as finger come upward.  Mated trans to engine and attached slave to release fork, aligned  fork within groove of release bearing.  Started the engine and tried to shift but it won't shift.  If I get the rear wheels off of the ground and shift it goes into gear without even pushing on the clutch.  I mean I can just pop them in all the gears except reverse.  Additionally, when in 1st and I rev the engine the rear wheel doesn't seem to spin as fast as it should, kinda like the clutch isn't full engaging.  Anyways, I took it apart again to see if there is something I did wrong.   Put it all back together and now my starter will not turn.  I replaced the started samething.  I turned crank with ranch and engine turns but seems a little hard to turn.  Now I am clueless as to what could be my problem.  I am gonna pull the transmission again to see if there is any binding causing too much stress for the starter motor.
So since you got the background here is the question.
Whats going on trans shift into all gears good, no grinding with wheels off the ground and not using clutch at all, but doesn't shift into gears at all with wheels on the ground both using clutch pedal and not?
A. Transmission no good
B. Clutch not engaging or disengaging
C. Write what you think
Should the pressure plate have alignment marks?  If so where?
Your help is appreciated, I can post pics but don't know how.
