Mack510
About Mack510
  • Birthday 06/11/1961
  • Gender
    Male
  • Location
    Hayward, CA
Mack510's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. I need two stock steel wheels for the 240z. I'm located in San Jose, CA. let me know if you have some to sell, where you are, and we can talk. Thanks
  2. More information: The Z20, Z22, Z24 are a 4 cylinder Nissan engine that came in some 200sx's, and Nissan 720 body pickup trucks. It was the next engine developed after the L series (L13, L16, L18, L20b, L24, L26, L28) The Z22 is a 87mm bore, and the pistion is 35.5mm from pin center to top, which I want to use in a L28 block that has been bored to 87mm. along with some L24 pistion rods.
  3. So your friend, looked at the outside of the motor and declared it to be good. WOW, He must have x-ray vision, or be all knowing! Stop listening to people who just have an opinion and look at the cold hard facts. Start by pulling out the spark plugs and looking at them. Is the problem only on 1 cylinder or all of them. Are the plugs sooty (dull) black, oily (shiny) black, tan/brown, or have a white coating. Check the plugs after starting the car and running for 1 minute, 5 minutes and a long drive. Take notes or pictures and compare. 1. Your engine DOES smoke when starting, thats a fact you can see every time to start it up. So what color (you already said its white) 2. As stated before in this thread, white smoke = steam, Blue = oil, Black = rich. So you have water or oil in the combustion chambers when the engine starts. 3. If Your engine is leaking water/coolant into the combustion chambers from the cooling system. It can't leak in from anywhere else, since that's the only water in your car. when driving the car, the radiator is pressurized to about 12 psi (look at your cap), but the combustion chambers get pressurized to about 100-200 psi. The pressure keeps the water out. But when you turn the engine off, the water is still boiling hot and the 12 psi forces a little water into the combustion chambers. Then when you start up the water has to burn off, but the combustion chambers are cold and so it takes a little bit to burn off (heat up). 4. OK, we'll take a flyer and say its not leaking, depending on where you live, there might be some condensation happening inside your intake which is getting sucked in when you start up, but unless its a lot of water, it would burn through pretty fast. 5. If #4 is true, you would never have to top off your radiator, If #3 is true, you will be periodically filling up the radiator or the radiator fill bottle. 6. So if #4 is true, park your car in a dry garage for a few days and see if the problem goes away. Then don't worry about it. If its #3, its either head gasket or intake manifold, or you have a cracked head (not likely as you would see more water loss). 7. If your engine burns oil all the time, you'll be adding oil all the time to keep it at the mark (dipstick). 8. Similarly the oil pressure is about 60 psi and when the engine is running the combustion chamber pressure is greater than the oil pressure and keeps the leak slowed. 9. Most oil burning during running is either due to bad valve guides or bad rings. You can check for bad rings by checking compression on each cylinder. Bad valve guides tend to leak a bit of oil down them, because it gets suck in from the top of the head (by the vacuum in the intake). 1 oily plug out of 4 or 6 would indicate you have a problem in only 1 cylinder and probably have a head leak. Write down what you have and be Sherlock Holmes, listen to the facts.
  4. I've been using Rob's machine shop in Hayward on a few L16-L18 engines and also had some head work done on various datsun motors and my toyota 4 Runner heads. They do really good work, and can build/do what ever you want from cheap and simple to complicated.
  5. anybody happen to have 2 used Z22 pistions (stock 87mm bore) laying around. I have 4 and need 2 more. Thanks
  6. Rotate the engine until you know its at TDC. The best way to tell that is to pop the valve cover and verify that both cam lobes on the #1 cyl are up (pointed sort of up). The timing mark should be on "0" deg. Now this is from a L16/L18/L20 background, but the L24/L26/L28 motor should be the same: The distributor drive should be: Small side forward (toward raditator), and pointed at 11:25 (like a clock). That is about 2 gear points counter clockwise from 12:00. Some end up at 11:28 or so and think its correct. if yours is not in the right place, drop the oil pump and re-install correctly. Then rotate the engine to 10 BTDC, or your static timing point, and install the distributor. The 6 point rotor should match up with the 6 point stator, and the top rotor should point at the #1 plug. If not, rotate the whole thing to get it right.
  7. Don't you watch Mythbusters??? A BF rocket motor. Sorry, couldn't help myself
