Dmartin_1
Everything posted by Dmartin_1
  1. Hi if you buy a rebuilt ECU do you have to change the chip from your old one? 1985 300zx non turbo automatic. I bought a ECU from autozone and someone said I need to change the chip. If so can I do it myself or send it in to change it.
  2. The bracker is beside the battery hidden in the inter fender it is the green one. Danny
  3. Theres no fuse in there for the power windows (in fuse box inside) will see if I can find a breaker the chilton manual don't help at all. Thanks Danny
  4. I wouldn"t thank both wouuld quite at the same time. Danny
  5. Hi have a 1985 Zx coupe neither of the power windows work Repaced the door switchs I found the fuse box under the hood by the battery.don't know how to tell if its bad or not . the repair manual don't tell anything about5 the windows. Thanks Danny
  6. http://torquespecs.tripod.com/maxima_85-91_codes.htm Here it is this will work on a 1985 300zx Codes and how to reset
  7. Dutson lover You were a big help thank you I found a bad Ecu Danny
  8. Ok I thank you have hit the nail on the head. Now how do I reset the ECU to take it out of safe mode?
  9. I'm just about ready to part this car out. I bought it for a parts car for my 300zx turbo but was a nice one owner so I just hate to part it out. But my patence are getting thin.
  10. Don"t know how. The trottle works fine the car just shuts the fuel off at 2200 RPm
  11. Hi I have a 1985 300zx that idels fine up to 2200 RPM then boogs out . Things Ive done so far replaced MAF also fuel pump and filter new air filter removed the CAT. didn't help.Took it to shop and they said bad mass air flo sensor so I took one off my other 85zx no difference. I put the old MAF back or my other zx it ran fine. wonder if it could be a bad conputer it read ok at the shop. or a shot in the witing to the MAF I don't know how to check that. Thanks Danny
  12. thats what wrong with mine it striped the splines out of the torq converter. The fluid is clean and not burnt but the car acts like it don.t even have a trans. in it.Two much hot rodding I guess,wonder How many trans. shops has charged you for a rebuild when it was just a torq converter. Danny
  13. Thanks my friend gonna rebuild mine for $400.00 he said the only week part is the torq converter. the spline seem to strip out.Danny
  14. Learned somthing new today from my tran. man 300zx tran. strip the splines out on the torc converter.Nissan was famous for this.wonder how many trans. shops charge you for a tran. overhaul when its just the converter
  15. I guess I could part them out on e bay everyone else seems to be doing it.
  16. Yeal I know its not as strong but I'm 65 years old and not a hot rod teenager. It turned out my donner car is to nice to strip for parts .now I have 2 non running 300 ZX turbo and non turbo. Thanks Danny
  17. Hi I have a 1985 300Zx turbo automatic and a 1985 300Zx non turbo Automatic I need to know if the non turbo transmission will work on the turbo.Also is the motor the same on a turbo and non turbo? And can I do away with the didgel dash on the turbo ZX? The non turbo is my parts car. The transmission is bad on the 300ZX turbo. Thanks Danny
  18. HizandHerz Thanks I'm trying to get hold of a friend and see what he will charge to rebuilt it. Also I heard that the clutch pack was the only difference. Danny
  19. Hay does anyone know for sure what automatic tran. will interchange with a 1985 300zx TURBO?
  20. Thanks I just got the car will check it out thanks Danny
  21. Hi I have a 1985 300zx turbo that went south.(pooped out) i bought the car this way.It doesn't do anything in any gear just like I didn't do anything. Is there somthing I need to check for before I pull it out? the fluid don't look or smell burnt. Now what other nissan transmission at my frindly salvage yard will inter change with a 1985zx turbo ? Thanks Danny
