ttarget
About ttarget
  • Birthday 08/07/1957
  • Gender
    Not Telling
  • Location
    Norway
Recent Profile Visitors
ttarget's Achievements
Newbie
  • Conversation Starter Rare
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. Hei. Jeg har en 1970 240Z med RB25det motor. Nå har jeg slått hull i oljesumpen. Jeg tror det er en RD28 olje sump som er montert, men jeg er ikke sikker. Jeg ser at mange skriver at de bruker RB20 med baksump. Har noen noen forslag hvor jeg kan få en ny olje sump som er bolt på, ikke aluminium.
  2. Yes please, if it is possible to get a description of how Subaru rack is mounted, I would appreciate it.
  3. I will assemble power steering on my 1970 240Z, which steering rack can I use? Some have told me that Impreza steeringrack is bolt on. Other suggestions would be appreciaded.
  4. I have a 1970 240Z mod. with RB25det engine. Now I want to mount electric power steering and need info. Want something that is easy to mount.
  5. I have new CP pistons with new piston rings but I do not know how much clearance there should be the piston rings. The engine develops 580bhp and I have heard that the clearance of piston rings must be greater when the effect is so great. If the clearance is small, it will destroy the cylinder. The engine is standard bore and compression.
  6. I will assemble RB26DETT in my Datsun 240Z 1970 mod and need someone who can make suggestions about how I can get the oil pan that fits right on? Oil sump will be back on the engine, how will I be able to check the oil level? I also want to overhaul my RB25DET transmission, where do I buy Repair Kit? Hope someone can help me
  7. I want to buy your brake booster if you have it yet. Have a 1970 mod (series 1) with upgraded brakes. Know that the 280ZX brake booster fit on 260Z, but do you know if it fits on my 1970mod?
  8. Need some information. I have a 240Z 1970 mod. The car has a RB225det mounted. Because the heat from the manifold is my brake booster destroyed (membrannet well apart). I have master cylinder from the 280zx. I would like to have slightly larger brake booster and do not know what is appropriate, can anyone help me? There must be a brake booster that fits without having to build something.
  9. Need some information. I have a 240Z 1970 mod. The car has a RB225det mounted. Because the heat from the manifold is my brake booster destroyed (membrannet well apart). I have master cylinder from the 280zx. I would like to have slightly larger brake booster and do not know what is appropriate, can anyone help me? There must be a brake booster that fits without having to build something.
  10. I have swapped an RB25det engine, transmission and a R200 diff in to my 1970mod 240Z. But I have a problem to connect my driveshaft to the R200. My skyline driveshaft didn’t have the same bolt pattern that the R200 have. What kind of driveshaft do I need?
  11. Hi VOODOOR33, I have same problem that you have, and I still search, if you have a specifikk adress where I can see where the vacum tubes to the intake manifold goes, I will be verry happy.
  12. My car have coilovers and no flares and I have diskbrakes rear.
  13. Can anybody help me with wheel information. I have a 240Z 1970 mod. and want to have following wheels size. Front: 4x114,3 17x8,5 et 0. Rear: 4x114,3 17x 10 et 15. Someone told me that this size will fit with out any touching. Please tell me if you know anything about this. Or may be you can recommend some wheels.
  14. I must have 18" wheels on my 240Z 1970 mod. because big brakes. My car have original chassi. Can anyone tell me how big wheels I can put on my car? Thank you!
  15. Hi. I want to swap a RB25det in to a 1970 mod. 240Z, and in this case I want to keep in touch with someone that have done it before so I can get some information. for example, I have the engine and the gearbox but what about the rear axel. I hope someone can help me. :icon5:
