Xnke
    9
Everything posted by Xnke
  1. In fact, a pressure washer can warp your body panels. on top of that, anything you rent will not likely strip the paint off the car. I'd go with the Aircraft Stripper + pressure washer method, it works pretty good. Properly applied and selected rattle can primer is exactly the same as any other acrylic lacquer or acrylic enamel, and put on properly will not rust. Does this mean you can primer a car and then drive it for months and not get rust? No, it means that the car, primed, sitting in a dry shop, won't rust.
  2. Also, even if it is not really toxic, Zinc Fume Fever sucks. it's way worse than the flu, lemme tell ya. Also, it CAN kill you, although it is not common nor easy to off yourself with zinc fumes. we're talking 2hr+ of a thick white fog of Zinc fumes... Know what you are welding, and know what it can do to you. Best way to be safe about it.
  3. Those chambers have not been unshrouded completely...look at the casting ridge around the intake valve seat. Everything i've been able to find on Hybrid, every L6 head porting post by 1FastZ, Braap, jmortenson, Johnc, all of them, says that that is one of the first things that needs to go. Maybe I'm wrong? Chamber looks to have been beadblasted, but i don't see anything really unusual; care to let us in on what we are to notice? (I've been staring at pictures of P90 heads for three hours now trying to figure it out...)
  4. Like i was saying earlier, what about the CA20DET? I think one in a 320 pickup would be just awesome. actually, any of the 4-cylinder based early datsuns would be nice with a CA or KA engine, i think.
  5. Sure, EDIS and Megajolt Light jr. would do the trick nicely, I'd think. I'm going that route with my SU-carbed L30.
  6. I have seriously considered putting a CA20(DET) (the 2.0's only came single cam, as far as I know, so i'd be using the 1.8L's head) into a 510, if not that, then a KA24DE(T). I'd imagine that the CA frankenmotor would do much better, especially if the CA18's crank girdle would fit. (i guess the RB20, 25, and 30 motors don't share the RB26's crank girdle, because the CA20 doesn't have one, but the CA18DET does) Would i be wrong to assume such?
  7. How about the CA18DET head on the CA20E bottom end? CA20E engines are plentiful around me, anyway. That puts you back in the realm of the SR20, displacement wise, and with a "better" valve train design.
  8. Looking for a set of N42 or N47 intake valves in good shape. New, Used in runnable condition, or suggestions on where to get them are all welcome. PM with info.
  9. Nobody here said "don't do it:". Just get the book, there is so much valuable information in there, it's idiotic to not have it. if I didn't have it, I would probably never have attempted the rebuild.
  10. You need to search around here. Get the Book. Book: How to Rebuild your Nissan/Datsun OHC Engine by Tom Monroe How to Modify your Nissan/Datsun OHC Engine by Frank Honsewitze Get them in that order, and you'll have everything you need to know. If the crank is not scored, then follow the directions in the book for polishing the journals and figureing the bearing sizes.
  11. If a dished piston is ok, get some ITM part number RY-6116-std. 87mm piston, 9.32cc dish, 35.5mm pin height. you'll need a set and a half, as these are for the Z22S four cylinder. I am using this part in 1mm oversize, and have zero deck height. If you need a flat top piston, though, i dunno.
  12. If you feel like spending a day up in bowling green, I can do it with just the sheet metal. I did mine in 18G, and they are plenty stiff, but like others have said, you'll need new underfloor rails too. It's a 6+ hour job just to form the sheets and get them fitted, not including the welding. PM me and we can discuss it.
  13. nah, just cut the front 3" off the auto tranny bell and ship the cut off part to me. Run In stand, anyone?
  14. And a square port header will work just fine on a round port head. It's been said and demonstrated many, many times.
  15. Yeah, I know, won't fit. Yet. Here's the deal: I like my Nissan "Iron Cross" 14" wheels. I'm actually looking for an extra to use as the spare. I work on (can't drive it yet...) a '72 240Z. I'm using the S12+8 solid rotor brakes up front, and will likely be using the '89 240SX rear disks with 240SX rear brake calipers. So far, the radius of the inside of the wheel is 6.75". fudge a bit for clearance, and call it 6.5". So, the brake rotor + caliper must have a total radius of 6.5" or less, at the part of the caliper that is farthest from the spindle axis. Now, the mounting face for the bracket is 46mm from the mounting face for the disk. (where the drum used to mount, sandwiched by the wheel) So now we know that from the disk mounting face, we need a 46mm or lso rotor height. (from back side of the friction face, to the back side of the mounting face, needs to be ~46mm.) the 200SX and 240SX rotors will fit the bill in this department at 46.5mm, and have a 5.06" radius, leaving 1.4" of room for the calipers to fit over the disk and under the wheel. I'll be making a trip to the JY tomarrow to pick up a set of mock-up rear brake rotors and pads (with the silly clips on them this time...ugh) and will update this thread with the progress.
  16. Well, after a long search and several failed attemps, I located some inexpensive S30 steering rack boots. AutoZone part number 03670 is a universal replacement boot, but is identical to the old part number UF2020. After removing the first large side ring, (these are a cut-to-fit type) these boots fit on very well, although you will need two zip-ties for the steering-rack side to keep them on. The hardest part is dealing with all the steering rack grease...after getting the rack clean, the boots went on smooth as silk, and fit securely. (With the zip ties on the rack side, that is. It may just have been me being stupid, as the directions say not to cut the large side of the boot, but I don't know how you'd get them on otherwise.) Regrease the rack, and waaaa-laa! new rack boots that you didn't pay 100+$ for from the Nissan parts desk, or 65+$ from most other parts stores. (including AutoZone, the S30 parts listing was 32$ per side) This universal fit boot was a whopping $9.99.
  17. examine that relay closely, and determine the pin connections. Then you can use any relay, or even two relays, as that one seems to be.
  18. Switched to pure argon gas today, made a HUGE difference in the little toy welder. It actually works like a MIG welder is supposed to work now, with CO2 it would sputter and spit, very little penetration, always welding on max heat. Now, I'm in the middle of the range, and have plenty of heat to weld in my new underfloor frame rails and subframe additions, as well as my new hand-formed 18G sheet steel floors. Engine bay is all but ready, and the EDIS conversion parts have been acquired, mounts made, and installed on the engine. Just gotta mount the coil pack, and the EDIS module.
  19. If you really don't want to upsize the valves, at least do the exhaust valve. you do not have to replace the seat to go with the bigger exhaust valve, but you should get the bronze intake seats replaced anyway. Might as well go with the bigger valves. By the way, L series valves are only about 7-8$ each new, from many suppliers. Or get a set from an N42 or N47 and use those.
  20. Does anyone know who makes or made this header? There are no markings, and i know that OTM, back when he was on this board, had the same header. Both my header and his were found an L26, the primary tube diameter is 1.5", the secondary tube diameter is 2", and my collector will merge the 2" sections together into a 2.5" exhaust.
  21. the extra duration of the C stamp cam is traded off for lower valve lift than the other cams, the A stamp cam has the higher valve lift, but 248* duration. C stamp: 256* duration, but only 9.X mm valve lift A stamp: 248* duration, but 10.5mm valve lift.
  22. Yes, the rear sill piece. It was available from Zedd Findings for a little while, but now there are no more. Very difficult to form by hand, a very simple part to press.
  23. So you're trying to mount that EDIS trigger wheel, but the best method you can think of seems to always involve machining the damper metal. What's the damper for the Venerable L-series made from? How about that 3rd row add-on pulley from that aftermarket A/C unit? Or most any flywheel? Some kind of cast iron or steel, but often hard as a rock! What do you do now? Here's some helpful hints for machining cast iron: 1. LOW SURFACE SPEED! This will save you more frustration with burned up tool bits than any other single thing. Even the soft, free cutting varieties of cast iron or cast steel will not tolerate a high surface speed. Get the lathe's RPM down! 2. Take a heavy initial cut. Take at least .020 on the first pass, at a low cutter advance rate. Almost all cast metals have a hard skin that is difficult to cut, and very abrasive. Once you get through, though, it's pretty smooth sailing. 3. Keep aware of your tool's cutting edge. Keep the tool sharp, every few passes or minutes of cutting, touch up the edge with a hone or check the edge of the milling cutter. A dull cutter will harden up the skin of the workpiece, and really frustrate the machinist that doesn't understand why he just can't get the tool to cut. 4. Use carbide tooling. For all but the finish pass, carbide will go a long way to achiveing your goal of a nice finished part, in minimum time. For your finish pass, usually a razor sharp HSS tool will give a better cut. For those with access to a tool-and-cutter grinder though, diamond hone a carbide tool's facets to nearly polished level. This will also give a nice finish on that last pass. 5. Keep a good chip feed going. Once you get the tool cutting, keep it in the zone. Don't get too agressive, but don't be shy. burnishing the cut edge will only dull your tool and cause you to have to stop and sharpen that tool again. Too deep a cut will break the workpiece, stall your machine, or worse! Also, watch out for hard spots in the metal. These can be detrimental to tooling life. Even when just drilling in a press, these tips apply. Slow the drill down, apply moderate to high pressure to break the skin, and keep up a good chip feed. Sharp drills are a must! Keep these tips in mind, and machining that cast iron part will be a breeze.
  24. Why not pull cool air from the cowl area? It's a much shorter run, less hose, and a high pressure area.
