butch9
Everything posted by butch9
  1. Hello, i have a '78 280z, and i want to replace my fusible links with a maxifuse block. I would like to know what (and where) i should purchase my parts, instructions, or a link to instructions, and any and all advice on what parts and just stuff related to a maxifuse install. and a new alternator and how to wire it with the fuse block, Thanks in advance!
  2. so i should remove the entire switch assembly?
  3. my '78 280z will only start if: when the ignition is in "on" and the emergency brake light is lit up. sometimes when i turn it to "on" the light will not come on, and the car will turn over and fire, then quit almost immeadiately. sometimes it will quit immeadiately even if the brake light did turn on. has anyone had this problem before? if so, solutions? thank you for the input.
  4. my "78 280z will only start if: the ignition is in "on" and the emergency brake light is lit up. sometimes when i turn it to "on" the light will not come on, and the car will turn over and fire, then quit almost immeadiately. sometimes it will quit immeadiately even if the brake light did turn on. has anyone had this problem before? if so, solutions? thank you for the input.
  5. i did the proper connection tests, and i've got good grounding. i am still having the same problem. still stuck...
  6. my '78 280z will sometimes run the fuel pump when he ignition is in the "on" position, but without then engine running, and sometimes it wont. when it is, then the starter runs very slow and i have no tachometer or dash lights and i cant get the engine to fire, and sometimes it does start, seemingly on random occasions. if i let it run, then shut it off, then try to start it again, it will fail and i have to wait about 2 hours then im back where i originally started. any thoughts? thank you for the input.
  7. Ive got a bone stock '78 280z and whenever i flip on a turn signal the engine is cut off, and so is most of the electronics. has anyone had this problem before? if so please leave your solution. and i am also getting low voltage to the starter resulting in frustratingly long startup times. Any help is appreciated. thank you.
