BobC-Z
Everything posted by BobC-Z
Saturday, August 17th, 2024, 9am–2:30pm (rain date Saturday, August 24th) Registration: 9am–11am Hosted and Sponsored by: 1400 US-22, Bridgewater, NJ 08807 Google Map to Bridgewater Nissan Save time at the show and preregister your car at: NJ Z Show Registration Portal Everyone is invited – you don't need to be a Member! Get there early, we expect a big turn-out. First 75 Z cars will receive a free Z Car Show tee shirt, dash plaque, plus a goody bag with lots of car stuff. Over 50 trophies to be awarded! 1st, 2nd & 3rd place trophies in Stock and Street Mod, plus Nissan Mod, Roadster, GT-R & Other Nissan/Datsun trophies. Lots of great raffle items, and a 50/50! Bridgewater Nissan is also offering 20% discount on parts purchases for the day of the show. Food Truck for refreshments and lunch. A family friendly event: no alcohol, please be respectful & polite to our generous hosts. Help promote the Show by hanging a NJ Z Car Show Flyer. Last years, over 100 Nissan & Datsun sports cars converged in our biggest show yet! Registration Fee (payable at the show) is $15 , $10 for NJZClub supporting members (If you'd like to support the club, we suggest contribution of $20). Looking forward to a great day shared with Z enthusiasts. Your participation is what makes this show so rewarding!
Hosted by Bridgewater Nissan 1400 US-22, Bridgewater Township, NJ 08807 Registration: 9:00am - 11:00am Save time at the show and PRE-REGISTER your car at: NJ Z Show Registration Portal Everyone is invited – you don't need to be a Member! Get there early, we expect a big turn out. First 75 Z cars will receive a free tee shirt, dash plaque, plus a goody bag with lots of car stuff. 45 trophies to be awarded! 1st, 2nd & 3rd place Peoples' Choice trophies in Stock and Street Mod, plus Ultra Mod / Roadster / GT-R trophies. Lots of great raffle items, and a 50/50! Food Truck for refreshments and lunch. A family friendly event: no alcohol, please be respectful & polite to our generous hosts. COVID conscious event -- all attendees will wear masks and respect social distancing guidelines. Registration Fee (payable at the show) is $15 ($10 for NJZCC supporting members) Looking forward to a great day shared with Z enthusiasts. Your participation is what makes this show so rewarding! Check out other upcoming events at: NJZClub.com
Sunday, September 16th, 2018 (rain date 9/23) Hosted and Sponsored by Acme Nissan, 2050 Route 130, Monmouth Junction, NJ Registration: 9:00AM - 11:00AM, Show ends ~ 2:30PM Save time at the show and PRE-REGISTER your car at: NJ Z Show Registration Portal In celebration of the club's 20th anniversary, all entrants will receive a large commemorative plaque with a picture of the owner and their car! Winners in each class will have their plaque customized with a plate recognizing their achievement! Everyone is invited – you don't need to be a Member! Get there early, we expect a big turn out. First 75 Z cars will receive a free tee shirt, dash plaque, plus a goody bag with lots of car stuff. 1st & 2nd place Peoples' Choice trophies in each class, Best of Show and the Dealer's favorite Z car. Lots of great raffle items, and a 50/50! Food Truck for refreshments and food. A family friendly event: no alcohol, please be respectful & polite to our generous hosts. Flyers are avaialble at: 2018 NJ Z Club Show Flyer Registration Fee (payable at the show) is $15 ($10 for NJZCC members) Looking forward to a great day shared with Z enthusiasts. Your participation is what makes this show so rewarding! Check out upcoming events, photos of past meets and shows, and recommended sources and shops at NJZClub.com
- new jersey
- new york
(and 2 more)
Tagged with:
Longer wheel studs for 76 280z
BobC-Z replied to Comrade_Charlie's topic in Brakes, Wheels, Suspension and Chassis
1993 - 98 Quest rear wheel studs are 45.5mm long from end to under the head. That makes them 13.5mm (0.53") longer than the stock Z front studs, and 4mm (0.16") longer than the rear. The Quest studs will press into the Z hubs and have the same M12-1.25 thread pitch. You can get them at most auto parts stores by asking for the application, or Dorman part number 610-403. -
Here is an alternative to adjustable lower control arms or strut mounts for a Z car. The goal: Adjustable camber without disassembly. OE Automotive components (for safety factor). Ability to raise the inner control arm pivot: To bring the roll center and bump camber gain on a lowered car closer to stock. To reduce OE bump steer (and not vary lower control control arm length which could induce bump steer). The chosen path was to make the inner control arm pivot (on the front lower crossmember) adjustable using cam bolts. Using camber bolts gives greater range of adjustment than is possible with eccentric control arm bushings. Because I was also raising the control arm pivots 3/4", I had to remove the control arm pivot reinforcing washers in the cross member. If not raising the pivot, you can slot the existing holes. The below photo of the cross member shows the spot welds on the upper washer (in the picture) drilled out and the washer removed. The lower washer is still present and the three spot welds are visible. The original inner control arm pivot and spot weld holes were welded up and new holes drilled 3/4" higher. The holes were then slotted about 3/4". Every 0.2" of slot provides about 1/2 degree of camber adjustment. Plan your side to side hole location and slot length based on whether you need to reduce or increase camber. Note that as you reduce camber, the control arm pivot will come closer to hitting the inside of the cross member. You can grind some of the material off the top end of the control arm (as detailed in the JTR manual (http://www.jagsthatrun.com/Pages/Datsun_Z_V-8.html), plus gain clearance by raising the pivot less (or not at all). Mock up what you want to do to check for adequate clearance before drilling & grinding. The below image is a roughing out of the slot (I ended up having to bring it to a machine shop to have it welded up a bit to true the sides, then final machined -- fair warning...). The key element is an appropriate cam bolt. Ford offers a camber adjusting bolt that is the same thread diameter as the Z (although a more coarse thread), with a suitable length, and best of all large cams that minimize the amount of fabrication required. They are available as Ford #'s F65Z-3B236-BB (cam bolt) and F65Z-3C178-AA (rear cam washer). Two each are required to do the job. You can also get equivalent aftermarket alignment cam bolts by ordering ones for the following applications: 1997 - 2003 Ford F150 1997 - 2002 Ford Expedition or Lincoln Navigator The cams on these bolts are large enough that they actually ride on the lower / outer flange of the control arm. In the below image, as you rotate the bolt clockwise, the cam push against the flange and moves the bolt inboard in the slot, reducing camber. Note that the machine shop also does sandblasting and powder coating! You still need something for the cam to push against as you turn the bolt to increase camber. I had the shop weld a small piece of metal onto the face of the cross member for the cam to push against. The location for this can be determined by inserting the cam bolt into the slot, and rotating it back and forth while holding a rod or pencil along the inside of the cam. For my purposes, the metal rod needed to be welded to the cross member near the inside top of the cam. If you are doing this mod without access to a welder, you may be able to drill and tap hole and thread in a short bolt for the cam to push against (make sure the bolt does not interfere with the control arm). In the below picture, the black section of rod is visible near the upper left of the cam. You need to weld the rod on the back side of the control arm as well, to ensure the cam moves in and out uniformly (the rod is barely visible top right of the cam): Depending on whether you removed the cross member pivot supporting washers (and how bad you buggered them up in the process), you will need to re-use them or buy new washers the same thickness for reassembly. The OE lower control arm bushing sleeve is not very thick, so if you get new ones, it is better to get ones with a slightly smaller hole and drill them so the just fit over the cam bolts, rather than to buy ones that have too large a hole. Note that as with any adjustable control arm or pivot, small camber adjustments result in a large change to the toe (you must do an alignment whenever you adjust camber). Here's to improved handling / reduced tire wear... Bob
Back view of cross member with cam bolt turned to the max camber (outboard position)
BobC-Z posted a gallery image in Members Albums
From the album: Adjustable Front Camber Modification
Images added to a gallery album owned by BobC-Z in Members Albums
A method of modifying the front cross member to allow the front camber on a 240Z, 260Z or 280Z to be adjusted with readily available eccentric cam bolts (from a 1997-2003 Ford F-150). -
