Well, since i last posted this: i inspected most everything in the engine compartment. found out that the engine was rebuilt right before it was parked. the oil in it looks brand new the carbs are crystal clean, everything inside looks pretty much spotless. the outside is basically just as good just a lil dirty. i installed new K&N filters and have fuel filters and everything. i know now that the clutch master cylinder is bad (i got the pedal to move) i also have the throttle linkage working flawlessly. bought a new ignition coil, and belt. so basically all i need to do is brakes, gas tank, radiator flush, and clutch master/slave and it should be in a good running condition. starter is good and motor turns. Also there is only rust in the drivers side floorpan (inch wide about 4-5 inches long) and under the passenger side along the frame rail (about a 2x4 inch spot)
