liveforeverZ
Everything posted by liveforeverZ
Just bought MSA injector kit, how to install??
liveforeverZ replied to liveforeverZ's topic in S30 Series - 240z, 260z, 280z
I did go to the junk yard, installed everything, and The Car Runs!!!! -
Hey , I bought the Summit 16gallong fuel cell w/ gm sender unit. They guy said it was basically just a two wire, ground/signal, sender that could be used on any car. Thing is, my 280z sender unit wiring has three wires. I'm assuming one is ground, one is signal....but what is the third and where should I put it. Thanks.
Thanks, its too bad I tossed them then lol. I'll have to find a place that sells them. -
What body kits were available in '72?
They arent starting production for about 8 months - which gives me time to restore. Its some drama set in '72. They were location scouting and just happened to see me working on my z , and asked if it was gonna be restored by then, and if they could use it in the movie - just in the background. -
There is definitely some gas getting in the case, however, definitely not 6liters - maybe 2 quarts - I'm not really sure where it could have gone. It isnt coming out the exhaust.
Hey guys, you may have read my fuel regulator post. I think possibly its stuck injectors in cylinders 1 and 2. I lost 6 liters of fuel in 15 minutes of starting it. It didn't come out the exhaust, so it must have gone down the cylinders. I'm thinking this is stuck injectors in 1 and 2 - does that sound right? I got it started today by removing the 1 and 2 spark wires and plugging them back in quickly. I think it spark flashed and lit the flood lol. Any ideas?
Hey Flash, Don't have pictures - in the middle of restoration. Its sterling silver w/ original mag. minilites. Really want to eliminate the rear bumper and fill the holes, and put an air dam on. The bre does look totally old school. Thats definitely a possibility. Thanks -
76 280z posibble regulator prob??
Hey, I multimetered the injector plugs while turning it over. It only showed .1 volt pulsations. I am sure that isnt enough to start them right. And the negative pulse was -.1v pulsations. -
Any good ideas on unclogging injectors? -
Wasn't the battery or the temp sensor. Is there a way to see if the injectors are firing? Like I said, the only way it starts is if I put the fuel in the cylinders, or if I blow into the fuel rail w/ a compressor while starting the car. It only runs then for seconds. This car was running perfect a few days ago. Also, as an aside, my fuel in my tank has turned red, and is burning brown. -
The tail lights and markers aren't a problem. I'm replacing the grill with the 240 grill just to even the space w/ the new bumper. The only thing I was worried about is the air dam. I was going to do the Xenon w/ ducts, but I know that wasn't available haha. Do you know if the BRE w/ ducts was available in the 70's? Thanks -
Hey guys, They are going to be filming a movie near me and want to use my datsun - however, the movie is set in '72, and mine is a '76. I was already planning on swapping my bumpers for the 240's, but really want to add a front air dam. Does anyone know what dam was available in '72?
i'll drop a battery with more juice in it today and see what happens -
Thanks guys. I've actully got another pressure regulator I'm gonna drop in. I've also got another coolant sensor I could put in as well. I checked the amperage on the batt, as well as firing order and all that. Battery was 8.8 cranking, so I think thats close enough to 9 to start it. Firing order was on. I'll put those two pieces in this week and see if anything budges. I just thought it was strange that when I doubled the fuel pressure, the car ran fine. Thats why I thought it may be a broken regulator or whatnot - but jasper, I will def. put the temp sensor in and see if the cold start was the problem. thanks -
Hey, Z was running awesome until I changed to hotter plugs. Then it stopped running. Thought maybe it was the plugs (checked - it wasnt), then timing (checked, not that either). Its getting fuel and spark, but wont start (turn over great though) Checked compression 152,152,148,150,148,150 (very cool for a never restored engine) I checked the pressure on the fuel line (38 psi) so that passed. I got it to start by putting my compressor nozzle right into the fuel rail and blowing 75psi into the line while turning the car over. It started right up. So for some reason, my car wont start unless it gets 75 psi to the injectors. I'm thinking maybe pressure regulator - any ideas?
thanks will definitely check it out
I'm looking for a set of injectors for a 76'. Willing to pay $100 shipped. Anything over 350cc/min , clean, and working, without needing any replacement rubber or seals. Thanks
Same, I've got a '77 l28, 70k ish, $300. I live in Massachusetts, though.
Can't find fuel pump relay!!
I have a '76. I imagine this will make a difference where it is. God know Datsun liked to move the electrical system all over the place. -
I've asked alot of people in the area, and consulted the factory manual...but still no location. People have told me its w/ the other relays behind the glove box (checked, couldnt find), near the injection relay under the driver side dash (checked, couldnt find), may be under the bracket w/ the fusible links on the passenger fender, and may be under a panel near passenger seat. Do any of these ring any bells for anybody. I'm dying here. Thanks. -
I can not find the fuel pump relay anywhere. I found the airflow/fuel pump relay under the drivers side facia, but I need to find the singular fuel pump relay. Anyone know where it is?? I've looked under the passenger side facia as well - nothing. I'm getting no juice to the fuel pump. Thanks
What is the best way to bench test a fuel pump relay? Thanks
