zblack280
Everything posted by zblack280
  1. I can tell you it has: 195 ports 10.0:1 compression 2.02 and 1.6 valves 1.52 ratio rockers 230-230@0.050 duration with 0.453 lift(in and ex) weiand accelerator single plain manifold but thats as far as i go with the info.
  2. I have a problem with my 350 and i cant figure it out so i am hoping someone here may be able to shed some light on it. Ever since putting new (well not new but very low k) heads on i have been having dramas getting the rockers set right. We have done the whole sequence of each cylinder firing and tightening so that you can feel some tension on the push rod, theres no slack between rocker and lifter but the push rod still turns fairly freely. then we do 90 degree(1/4 turn) to set. IS that correct way to do them? Problem then is that they are still a bit noisy and now it has developed what i can only describe as popping through the carby at full throttle above 3500rpm or a bit lower under load. to me it sounds as if the inlets aren't closing fully, we have tried a couple of different ways to set them. Ie: doing inlets when the exhaust just starts to open and exhaust just before the inlets fully close. We have tried half a turn instead of 1/4 etc etc... We have tried timing at 12,10 and 8 degrees and also gave it a stab by ear and no matter what we do the "popping" persists. Does anyone have any idea as to what is causing the "popping" sound. Just to ad when i first put the heads on it was fine just a bit to noisy for my likin
  3. was also wondering if a z31 300zx crossmember and rack would fit in the 280?
  4. good stuff thats what i like to here, makes the chev conversion much easier and roomier.
  5. I was wondering if the front crossmember from a 280 with rack and pinion steering will simply bolt in to one with a reticulating ball steering box setup.
