yes thats what im after, My S12W measures about 54mm so was hoping there was 2mm between the two models.
I am fitting these to a Toyota and the standard mod is the S12W with a 20 @ 268mm rotor the problem is this rotor needs machining & mounting holes redrilled costing $120.00 extra.
I have located a 24 @ 270 mm rotor with the correct mounting hence no machining, but still not sure if this will fit as the S13w would need to be 56mm,
I have been trying to find a set here (australia) no luck as yet.
What is the weight of the 240Z ?
The toyota is 1140Kg, are people having problems with the S12W setup?
Im now thinking use the 20 @ 268 rotor like people say its overkill anyway!!
Manuel,
