Ph34r
Everything posted by Ph34r
  1. http://www.4secondsflat.com/RB%20Cam%20Specs.htm
  2. Just to be sure, when the new intake mani gets here I am going to get 6 new ones and a new rail. Next is replacing the ECU... Do I need a 79 specific or will 79-83 NA work?
  3. Ok, new AFM in... no luck, but I think I my have found an issue... Of the 6 injectors... 3 are black, 2 are yellow and one is green...
  4. Thanks again, I'll get to that today and see what pops up.
  5. Ok... Still an issue... What I have done made it better.... there is always a but... I hooked up a A/F tonight http://www.knfilters.com/airfuelmonitors.htm Was running at the top of the chart 13.2-12.1 with the TPS hooked up and a bit leaner with it disconnected. I am stuck... gas mileage still blows nuts and there are serious performance issues. My only ideas are the AFM and the ECU itself being shot. I will linetest the system tomorrow. And I'll start the search for a new AFM. (Anyone want to sell a good one? Or want a tweaked one in partial trade? *Using the search tool... * I found that the vac line to the FPR may be an issue so I will check that too... Any other ideas off the top of your head?
  6. Update... NEW CTS, NEW OEM Thermostat, MSD Blaster 3 and an optima redtop... bat out of hell... Thanks again guys, worked like a charm! Jason
  7. I am putting the Borla muffler on... I'll get a video when it's done.
  8. LOL, I have had my fair share of vehicles with VAF/AFM whatever you want to call them. I'll check the CTS today. I am gonna go get the AFM from the 81zx that is in the yard here and try the and see if it makes any difference. Appreciate all the help!
  9. Baller... since I am running at lower temps, would getting a low temp thermostat help this too?
  10. There is a writeup that shows you that there is a carbon "Trail" that the Air flow meter uses to send the signal. And that over time it can wear down. http://www.geocities.com/jfairladyz/AFMrebuild.html?1144191577198 But I think that someone has messed with the AFM (It was sealed up with silicone and badly I might add). So I am looking for a new, untouched one to try And to adjust the TPS I used the FSM to properly adjust it. I understand how it all works, just trying to narrow down the problem. And no, I have not checked/cleaned the water temp sensor. Would that be affected by the fact that I run super cool all the time? I have a 16inch flex-a-lite and a turbo radiator... car rarely gets over the first line on the thermostat and I am in Florida. Thanks again... and if you ever need tech/computer help... let me know...lol. I am A+, DCSE and MCP. And I owe you guys whatever help I can offer.
  11. I have an odd issue, did some searching here and didn't find concrete answers. So I figure I'll pose the question for the masters to ponder. So... When I go WOT on my 79 L28e it feels like its starving for gas... BUT! I got under the hood and was looking at all the things I read to look at. I adjusted the TPS, cleaned the TB. Opened up and refreshed the MAF. Still no go juice... So in frustration I unplug the TPS and the damn thing runs like a bat out of hell. Any ideas on what could be doing it? And one other thing... I have several TB's from 240sx's and want to do the swap. Do I have to run any special wiring to the TPS or is it pretty much plug and play? I have the spacer machined and I am in the process of cleaning out a plenum for it. Thanks again... Ph34r
  12. No one has one? Damnnit... the FSM doesn't tell me anything... I really don't want to have to pay the $125 I got quoted by a local Z shop to have them do this... anyone??????
  13. Lol, I would, but I highly doubt they are right to begin with.
  14. I am going to be cleaning the engine bay and while I am there I am going to replace the vac lines with new ones. Does anyone have a vac diagram for what goes where? The lines that are there are in crap shape and I would rather just re-hook everything back up the right way. Thanks Oh, it's a 79 L28E
  15. Cool, that is what I was looking for. I'll chill with the L28 for a bit and see if McKinney gets a donor car to fab one up on. Ph34r
  16. Looks like the crossmember is there, but I could be mistaken.
  17. 66 views, no replies... weaksauce **Edit** Just got a reply from McKinney. So ... looks like I will be making my own then. Thanks
  18. I have been looking around and see that they make mount kits for S30's. Does anyone make a kit for the S130, or will the S30's work with my S130? Just got a 79 280zx and gonna drop the SR I have here into it. Thanks in advance.
