1979280zx
Everything posted by 1979280zx
  1. Just got back from the track ran a 7.52 @ 91mph
  2. Dont no what it weighs an yea it holds 15psi to redline
  3. Just got back from the track went a 7.71 at 90.97mph
  4. Have to put a clutch in it now it dont like the extra power
  5. Last night I ran a 8.6 at 86mph in the 1/8mile on 15psi
  6. It all the na stuff with a rrfpr an 280zx turbo injectors
  7. Got a new time on the car 10.47 at 73mph at 5psi of boost. What should I run the timing at to run 15psi of boost.I have a n42 block with dished pistons an a p90 head now.I know my compression is lower now so just wanted to ask.
  8. I got that problem figured out. The thing now is you rev the car an it stay at 3000rpm an you have to shut it down an restart it again to get it to idle
  9. the car is a 1979 datsun 280zx. it is a na engine with a t3/ t4 turbo. the car just started doing this never had it happen before. at 5 pounds of boost I get 65 pounds of fuel pressure. I am running a msd 6al ignition box. I have the timing is set at 22 degrees advance.
  10. Title says it all its got me stomped boost hits at 3000 rpm an it dies an will not pull anymore
  11. yea an shaved every thing off the intake the only thing bad is the fuel pump craped out last run an i blowed the motor because it ran lean. r you running stock na pistons in your motor
  12. still needing some pistons anybody got any
  13. done a few things to the car over winter an took it to the track the other day an ran a 9.51 at 75mph on 5.5 pounds of boost
  14. i dont know wat you want for the two
  15. i need two turbo pistons or a set thanks craig
  16. wat do you guys lunch your car at at the strip
  17. i need a smaller turbo because my 79 280zx has a steering box an dont have much room my stock turbo took a crap need a new one not looking for no big hp numbers just need it to replace the old one
  18. is this a good turbo to run with the l28 .57 COMPRESSOR WHEEL TRIM.50 A/R COMPRESSOR.63 A/R TURBINE
  19. car is running 7psi an on street tires first run was 10.01 aT 72 mph next was 9.93 at 73 last was 9.77 at 73. i want to run 10 pounds next about were would i set the timing. im at 18 deg. locked right now
  20. nobody knows heres the link to the strut rod bushings http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Strut+Rod+Bushing&currentPage=1&categoryDisplayName=Suspension+%26+Steering&navValue=14600012&itemId=12-0&parentId=46-0 or they the same as tc rod bushings
