rwill300x@hotmail.com
Everything posted by rwill300x@hotmail.com
fuel filter change TIP (1980 ZX)
rwill300x@hotmail.com replied to PhilbertZ's topic in S130 Series - 280ZX
Funny, I've found many things in my Haynes manual that are wrong! From what I hear, they are better than Chiltons. And now for my question to you. What made you decide to change the fuel pressure regulator? -
I need an ECU and a starter....and maybe some more stuff. As I said it's an 82 280ZX non turbo 5 spd, but for anybody that might know the answer to this question... The old ECU says "do not use on anything but an 83' 280ZX"..... Yeah, I bought it like that, but it's run like a bat outta hell for almost a year. Sooooo, can I get away with putting another one from an 83?? I live in Magnolia and I need it quick! Thought I'd give it a try, if you do hit me up PLEASE!!
So I have everything back on and she won't start! The timing is straight, new cylinder head temp sensor, new plugs, new conecter wires (the old ones were corroded) new vaccuum hoses, (lookin to eliminate those as soon as it's running again) The starter is not engaging now, it turns and starts whining, not turning the flywheel. Taking it to O'reilly's on the way to work to check it. :fmad: BUT HERE'S THE PROBLEM THAT I REALLY NEED AN ANSWER FOR!!!:fmad: When I turn the key, the ECU is supposed to flash the light I think five or six times within 10 seconds. All it does is blip once. That's it. I was wondering if anyone knows what it's trying to tell me, what does that one blip mean? Thanks for all the help yall!!!
I can't stand these flapper style meters, I like the free flowing pin style I had in my 300ZX. There's a post on this forum to do the conversion, but I have enough on my plate! I have the new T/C and tensioner on there but still haven't started her up yet. I have a silcone hose set on order. The tensioner was all ate up, I cleaned all the connector terminals by pulling them out through the back and cleaning the whole thing and sliding it back in and packing it with die-electric grease. Have the sensor on the thermostat and a cylinder head temp sensor on order too. I need to replace every single connector on this thing. It's really trying my patience with all the corrosion, and that 26 year old wiring! I hope to get them online and re-wire it. Ultimitly I want to MegaSquirt it. I like the set up they have, I've heard they are pretty darn good! You get rid of all that old wiring. Also, I replaced my front sway bar bushings with poly. I got a set from Energy Susp. a few weeks back and already did the rears. Now I need some strut inserts, BAD! Only problem being, Modern Motorsports LTD. hasen't gotten back with me about an adjustible coil over set up, that is the only one I want on there! They stopped making the rear Illuminas for the 82's. Don't know why? Anyways, I picked up some clevis pins and some lynch pins so I can make my own hood pins.
Hey, I was wondering if anybody knows how to get the electrical contacts out of the connecters. Is there some special tool? I pulled on a few of them and they came out with a lil persuasion. I have to clean the entire copper piece inside because they are green all the way through!! I got a few of them cleaned up and put die-electric grease through and through and taped them up. I'm gonna hope for the best now.... ***UPDATE*** So I pulled the front cover to change the T/C and the tensioner was ate up, I've got pics coming soon. Then, as said above I cleaned all the connecters and greased em. I ripped my cylinder head sensor, the WIRE was barely holdin on. Every strand was broke on one of them and only ONE was connected! So I think the C/H temp sensor was to blame for a lot of the problems. Now I have to get a new connecter and fix that and another one and then...well, hopefully it starts!
So I ordered a T/C kit from The Z Store, should be here soon. I got a gasket kit from O'Reily's, it covers everything I'm gonna take off. All but the oil pan gasket, I ordered that just in case. Yeah, I looked it over in my manual, looks like fun! It's my first time doing it, but that's just how I learn. I feel you on the pride issue, I'm goin high compression, I want at least 300+ hp. I know these motors are capable of doin it, the LS1 is definitly in my mind for future plans. I want to have a killer Z, but be able to say, it ain't turbo. THAT'S impressive!! I love Z's, I want to own a 260Z 2+2. I never liked 2+2 models, my first Z was an 86' 300zx and I couldn't stand those four seaters, but those late 70's 260's are TOUGH! Of course, I would gut it, no back seats in my Z's. But yeah, I'd like to put a LS1 in that!
So the chain is stretched....There is WAY too much slack in the T/C. I'm about to get a kit and repair it, see what that does. While I'm under there I'll be able to see those marks, which is good, cause it's buggin the hell out of me. Also, I think the coil might be messed up, don't know? My pop checked the resistence of the wires, but we don't know what is normal. I plan on getting some more wires soon, and a new coil. LX-91 from Crane Cams, I have one on there right now and I definitly recommend them!! I picked up some CRC contact cleaner and die-electric grease on the way to work, so when I get off I'm gonna get to work on the Z. Thanks for the responses, all a great help! ZXWILLY
Ok, the engine is a non turbo 2.8L I-6. Unsure if it's bored, the guy who I bought it from did some work to it. Mild cam, Fire Ball coil, straight 2 1/2in pipe into a Ravin performance exhaust. Runnin the recom. NGK plugs. Haven't done a compression check in a few weeks, last time all cylinders were at 181psi, except 1 and 5 had around 123psi. About 10-15 more than the manual said it should be. Oil pressure is steady at 60psi, it did drop and then came back up, but as far as I know it's fine. All day yesterday I was messin with the timing chain and I moved it 1 tooth, IT STARTED! Ran like ♥♥♥♥, but it ran, oh, that was after we put some starting fluid in the manifold. I think it just needed that to get started, cause it ran without adding anything again. Moved the chain again, not much change, then I moved it completely back the other way to where I started, then coming back one the other way, advancing it, and it almost sounded like it was back to square one.....It doesn't line up on the crank pulley though. It runs, but still "limps" like it did on the way home from the track, that's why I say back to sqaure 1. I think it's a sensor, all my contacts are green, gonna clean em up with some CRC when I get some time off. I found one sensor beneth the thermo housing with the wire completely broke off! Can't figure out what one it is, WILL TRY AND GET SOME PICS SOON!! I'm trying to cover everything and it seems like forever talking about it, but TYPING?! Plugs- Everytime I pull my plugs they are coated in carbon, AND gas. The car has run rich since I bought it. The # 6 plug fouls quicker than the rest, I checked the fuel injecter connections and 5&6 were green, cleaned them up with some CRC spray. Still, I can pull the #6 plug while it's running and it makes no difference in the idle! Well, Thanks to GEARHEADSTICK, I had a light go off in my foggy brain! When I pulled the valve cover it smelled like fuel! I'll check out that fuel pressure regulator. Oh yeah, the fuel filter, I pulled it off and nothing but clean fuel came out, I just changed that like 2 weeks ago. One heater hose underneath the intake manifold feels like silky smooth, don't think that's doin too good for my vaccumm, gonna pick one up when I get off. I do plan on checking the valve clearences tomorroww. A few other things that are in the plans: I have a T-5 that I picked up that is missing a short throw shifter. Somebody thought the meaning of "short throw" could be achieved through cutting the shifter and re-threading it....jackass. Also have a turbo flywheel that needs to be cleaned up. It has an R-200 diff and I have a brand new MSA turbo driveshaft to mate up with the T-5. I have many pics of the diff and everything as I had to replace the mount bushing on the diff. I was on my way to my Grandpa's house on Christmas and something started bangin around and it went along with the speed of the car, it was intermittent. SO OVERALL- Moved the timing chain over one tooth and it came back to life, still havin a problem with it stumblin. Scared shitless that the timing is off and somethin is gonna burn up or break. Haven't run it up the road yet, had to work....and here I am.
So I decided to hit up Houston Motorsports Park on sunday's "Run Whatcha Brung" and race my buddy's 04 Mustang. I have a 1982 280ZX N/A that runs like a scalded dog. The first run, the ole Texas Bullet took off impressively and took the stang a half a car the whole 1/8th. Let the cars cool down, watch a few busa's on roids tear down the track at like 125 mph in a few seconds. Some Nova's and trucks with nasty big blocks pullin wheelies, then run em again. This time I got a better burnout and took him again, cutting the light and tearing down the track I ran slower mph wise, but I got such a good reaction time that I got a better ET. Well, after the second race, she started limping back to the pits. Sounded like the plugs were acting up, a cylinder wasn't firing, or a valve was sticking. It sounded like it had such a big cam that it wouldn't barely idle. Put some fresh, correctly gapped plugs and nothing changed. Checked the air filter, fuel filter, vaccumm everywhere, injecter connectors, man I think I've checked just about everything! Well, that's not all the problems, then after I saw my fuel gauge was on 1/4 tank, I thought maybe something got sucked up into the pump, but that's not really a concern anymore. I filled it up with the usual 93 Shell and still, no change. On the way back to my buddies house, she won't get past 2000 something RPM's. It keeps bogging down around 2 something grand, then you have to shift all the way to 5th where you can only go 50 and it sounds like something is about to break. THIS CAR IS UP TO 50 MPH IN SECOND GEAR!! pull the plugs and they are fould out....I just put brand new NGK's in there at the track! We had it in the parking lot of his complex from like 1130P to 1A revving it up listening for vaccumm leaks meanwhile a cloud of smoke is overtaking the parking lot. It is running, but it's running like crap! The next morning it starts a few time and I go to check the ECU fault codes, now it won't start...... Yeah, I know, it's more than likely fried! I heard if the green light comes on then it's still good. Don't know how much truth is in that, care to comment?? Now it turns and turns. I have fuel, fire, and compression....still no run. I've heard it could be cylinder head temp sensor, ignition control module. Also, I've been told it IS possible to jump time, but it's hard when you have a chain, but also that you won't jump time with a chain..... I was runnin her somewhat hard, I can't lose to a mustang! I'd really like to see if anybody has any useful info, I know it's a few things, but if you see something that I wrote that sounds familiar and know a trick or something. Thanks, ZXWilly
Z31/300zx ECU/MAF to 280ZXT swap guide
rwill300x@hotmail.com replied to Afshin's topic in Turbo/Supercharger
I dont know if you can help, but here goes. I have an 82 280zx that has an old flapper style AFM, i used to have an 86 300zx and I liked the MAF on it versus this one. is there any way to change them out? i understand that you had a turbo, mine is not, which sucks, but none the less i want to change out that old AFM. would i have to change the ECU or anything else? or do you know of any conversion that is offered? i have looked with no success. thanks for ur time. ZXWilly
