Thanks for the reply. First thing I will do is go through and check every ground. Then I'll do like you said and trace the wires with a multimeter. All the fusible links look good and all the stock wires are in good shape as well.
This is my first car build up so bear with me but another question I have is with my starter. It has an "upper terminal," which I hooked the positive battery cable to, a "lower terminal," which the negative terminal is hooked to, and a "spade switch" which I hooked the black-yellow wire to. Does this sound correct? Thanks
