Changing the rod bolts is a HORRIBLE idea. By you changing to ARP rod bolts you have most likely shortened the life of your engine and most definitely not improved anything. Stock rod bolts are fine unless you want to be doing 7k RPM, and moving up to a stronger rod bolt that gets torqued tighter can deform your rod caps causing beat up and maybe spun rod bearings. If you want a cheap bump in performance just go for a LS9 camshaft and springs.
