I'm hoping someone can help me with a question on engine break in.
I have 74 260z with a SBC 350 that i've recently had rebuilt (bottom end only) and today we were supposed to break the motor in.
The entire top end had been put on and the cooling system in place and we filled the radiator. The first issue I noticed was leakage from around several freeze plugs. Although it wasn't gushing out, there was a steady drip from at least two of the plugs.
We weren't entirely happy about but figured that we could fix it with some Bars leak.
Ok so onto pumping oil up into the top end of the engine. We added five quarts of non-detergent oil to the engine and a filter. We then attached an old distrubtor without gears that would engage the oil pump. We also put on a oil gauge outside to be able to read the pressure as we worked the oil pump.
We put a drill motor onto the old distrubtor and slowly turned the distrubutor so that the oil pump would push oil through the engine. This was going fine for about 10-15 seconds when the drill motor seemed to "seize". I could see the pressure reading at about 40 and when the drill stopped it slowly fell to 0. I pulled the drill off the distributor and cranked it by hand.
Two things i noticed. One, I could get up to 40 PSI with a few quick turns of the distrbutor. The second issue was that the distriubtor was really fighting me so much that after about three turns by hand it wanted to back out - kind of like winding a rubber band. We had the valve covers off and on the several of the push rods oil spurted out.
I thought maybe the filter was the issue (wrong type for the car) but verified that I had the proper one installed.
I spoke with a different friend who said that there should be no way to get up to 40 psi oil pressure by just turning the distributor by hand.
Now i'm wondering if the oil "passages" in the engine weren't propelry cleaned and that the high PSI is from the oil being forced through the clean passages.
Has anyone experience a problem like this on break-in with very high oil pressure?
thanks!
