Jp76z
  • Location
    United States
Jp76z's Achievements
Newbie
0
  1. Thanks for the reply, Im leaning toward the run side of the coil. This wire is connected to the resister? which one is it. See I have constant power at the pos side of coil with ign on. I removed the afm and cut the harnes so i was jumping the fp relay.
  2. Hello people, I have start and run issues that I believe has to do with the ignition unit, or power going to it, or some open circuit relating to that. So this was a running car untill.... I installed a turbo head and the parts needed to turbo it, along with megasquirt 2. The ms is for fuel only right now and made my own harness adaptor to go from the ms2 to the stock harness using the connector from the stock ecm. I had it running off of ms before i took the engine apart using the stock ignition like im doing now. After putting the p90 head on it and stock manifold, I got rid of all emisions and everything else exept clt sensor. I added a few, so the only sensers that i have are tps, clt, iat, o2. i cut the plug for all the other sensors off to clean the harness up untill i make a complete one. Also i have high ohm inj's so i eliminated the resistors as well. What is happening is the engine is trying to start while cranking and firing, untill i stop cranking. I dont know if i made an open circuit cutting the harness up, but I jump power to the main relay for the pump and all, have power to the injs and coil when key is on. the injs stop clicking when not cranking and I believe its because the coil stops sending the signal to the ms. BTW, the ms is triggered by the negative side of the coil as a tach signal, and fuel psi is good.. I have not yet checked all the powers to the ignition module yet. Does this ring any bells, or anyone have any ideas?? Any opinions or help is greatly app.
