I noticed that regarding caliper piston size, the numbers are not always accurate...
Usually, when I need information about piston diameters, I go to RockAuto.com that has pictures and measurements posted on most parts they sell. For example: the 4 pistons of the RX7 caliper have a 36mm diameter and the 240Z has two 54mm pistons. See attached pictures of the RX7 FC, RX7 FD and 240Z calipers.
With the Total Piston Area Calculator we quickly find that the RX7 has 8138.88mm² and the 240Z 9156.24mm² on the front axle. This information tells us that we would lose 11% total piston area, and therefore clamping force would go down 11% as well.
If the rear brakes were not participating enough and pedal effort was light to begin with, this could be a very good swap. On the other hand, if pedal effort was high already, and the rear axle was over-braked or perfectly balanced with the front, the swap would require a serious look at (and possibly redesign of) the rest of the system, in order to make it work right.
For example a slightly smaller M/C (to compensate for the reduction in Total Piston Area up front) and adjustable proportioning valve (to reduce hydraulic pressure increase (with increasing pedal pressure) to the rear brakes). Or even a larger rotor and moving the front calipers outwards on that rotor to increase “leverage” to increase torque. Another way to increase brake torque on the front axle would be to go with pads with a higher friction coefficient... As you can see, the possibilities are endless... Hope this helps.
Arne
