Niku-Sama
  • Gender
    Not Telling
  • Location
    Deadford OR
Niku-Sama's Achievements
Newbie
10
  1. i live that, i posted at z driver so i thought i should post em here. you posted them like a YEAR ago. the new wheels look alot better than the ones you had though, mucho alot!
  2. carbon canister? dude on a maxima message board has his go bad and cause the same thing...some how
  3. what the heck, i have to agree to the rules every time i log in now? something is messed up i think. any way, nah on the z31 still. i've got a new set of injectors going in soon when i get off my ass and order the end o-rings for them and then i am going to give it a shot. if it doesent work, meh no big, i paid like $8 for it if it does then after i get my next car in order to drive arround i'll go to work on punching out the intake and cleaning up a few things. might be time for a rebulid, only 88k miles but smokes on deceleration with the clutch out and in gear (engine braking). blueish smoke too even but the pressure rises when i am not stepping on the gas and i am engine braking so it could be something PCV related. of course i dont do it all the time and its not currently insured so i am not driving it.
  4. i really dont see much point in swapping an engine harness and everything, not to mension i would have to weld a O2 sensor bung into the exhaust manifold and i really do not want to do that, all in all thats too much work than swapping the afms and adjusting if it works.
  5. i say rebulid it if your going to be using carbs on it. might as well
  6. any way so the feasability of this with out swapping guts, how feasable? going over it several times i cant imagine its impossible, mabe some adjustments. i mean its going to act as if the air temp is 10 ohms warmer over the Z AFM but thats at room temp as well and it'll also throw some readings requireing slightly more fuel but not much more than normal either. and thered be more air to burn up aswell when i do it i guess i'll have to do some narrow and wideband air fuel guage readings or just wing it and see....probally just wing it. been thinkin about rebuliding any way if in the unlikely chance that something major happens it'll just give me the excuse to. i've already replaced the coil with one of those blaster MSD coils, little bit of improvment there, and i have a set of good non leaking injectors that i'll stick on with some new seals before i do this. i have some on there that are seeping, pretty minor but any fuel out of the side is fuel thats probally meant in the engine and a loss of cc's
  7. well its like taking a cold air intake the next step further
  8. oh i thought that was for a turbo. see the thing is the resistance values are minor between the 2 and i think most of it may be due to an age thing, 10 ohms difference on the air temp, i could see 10 ohms difference easy between similar year AFMs from 280s depending on milage and how crusty (basicly) i mean its a 77 280z but theres no word on the year of the cressida AFM, the one i got is from an 86.
  9. i havent been arround for a bit but i still have my z but any way... i managed a decent cressida AFM a while back out of a PaP in washington for cheap and i was wondering if any one had tried one on a NA car at all. i figure open up the intake a bit and swap the AFM over, and by open up i mean the manifold it self and the throttle body. if not i guess i am gonna guenna pig it, and see if i can get it to work. while i am at it i was wondering if any one has the pinouts for the plug on the cressida AFM, i might as well see if i can get away with out having to swap guts seeing how mines NA and all i figure i might have to adjust the spring and mabe lower some values with resistance.
  10. dont you have to change the harness for that? i mean thats great and all when the harness in your car is shot but i dont see much sence in hacking out a good harness for something like that. i think i am gonna head to the yard, there were a few cressidas out there and i'ma gonna expairment with one of these AFMs if i can find one. i also need to see if i can get some tires for this ♥♥♥♥ camry i am driving. it just rolled over 390,000 miles on an ODO that was replaced with a NEW odo because the old one broke after a few 100k
  11. yea people keep saying that but it they still test ok so i donno
  12. i found almost a whole socket kit in the radiator shroud...sadly they were standard sizes
  13. cressida AFM? how is that an upgrade? edit: ok i found this: http://www.atlanticz.ca/zclub/techtips/afm/sizeupgrade/index.html is this a direct swap on a NA? i cant tell if they are comparing and replacing guts with a turbo or na zx afm in that link
  14. yea please do, i am headed back to where my car is next month and if i can fix it then that'd be grand because by then i'll know if i need to bring it back up here to washington or take it down to texas
