well since im in iraq and couldnt get approval to post the link prior to it being deleted...here it is again...thank you my AF brother for deleting my thread
this is a military group buy in...open to all no id is required its just that my self and another guy here in iraq set this up...
RPSport.net is the company offering the buy...it is only open till the end of the month...sorry for short notice...5 is the number needed
im in for 2 and stricnynel0s is in for 1...we are the 2 who started this
it was originally posted on nico but all who were interested have backed out...
i was hoping to spark some interest here so like i said b4 if your intersted PM me or send me a message on yahoo or aim, toadx8u, and i will link you to the purchase site...
DETAILS:
High Performance Fuel and Ignition ECU
With 14 channels capable of controlling injection and ignition duites, the Platinum Sport 2000 can support most modern engines (including 3 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CDI systems.
It is capable of controlling sequential injection on 4,6,8,10 & 12 cylinder engines and direct fire ignition for engines up to 6 cylinders, or wasted spark ignition on engines up to 12 cylinders.
Features:
- 11 additional user-definable auxillary inputs
- Up to 13 additional user-definable auxillary outputs (Depending on configuration)
Features and user-definable outputs available as standard include, but are not limited to:
- Fully user-definable 32 x 32 mapping ( Up to 1024 points)
- Wideband "Auto tuning" using user definable target AFR table
- Narrow and Wideband closed loop O2 control
- Staged injection control for multiple injectors per cylinder (inc rotary)
- 3D mapped rotary engine ignition split
- Soft and hard cut rev limiter
- EGT fuel correction
- Tuning via TPS with manifold pressure correction
- Dual map switching for fuel/ign/boost
- Anti-lag (Rally and Launch style)
- Rotational idle
- Launch Control
- VTEC cam timing control
- VANOS cam control (intake cam only)
- True variable cam control supporting late model Toyota's, WRX's and EVO's
- Dual intake runner control
- Onboard 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
- Custom sensor calibration (Use your own sensors for temps or fuel/oil pressure etc)
- Open or closed loop boost control ( Road speed, RPM or gear based mapping)
- Closed loop idle control (Stepper motor and BAC type)
- Extra injector control
- Thermo-fan control ( Duty cycle or on/off )
- Intercooler fan/spray
- Alternator control (Mazda)
- Engine control relay function
- Nitrous switching with fuel / ignition correction
- Staged shift lights
- Aux fuel pump control
- Tacho output (5v,8v,12v)
- Turbo timer
- Torque converter lock up
- Air con request idle up
- Windows 2000, XP, Vista compatible software
- "In the field" updatable Firmware provides all the new features as soon as they are available
- Onboard and laptop data logging with Data Viewer software
- USB communication with laptop/PC
- CAN Bus port for direct plug in communication with Racepak and Aim Dash system.
Typical Applications: - Control of fuel injection on modified engines
- Conversion from carburetion to fuel injection
- Race and rally applications of all description
- Design and development purposes
- Educational use by universities and technical colleges
- Original equipment in cars and motorcycle
At least 5 ecu orders must be taken within 7 days of the first order, if not the previous orders will be refunded on the eighth day.
Shipping is included to a continental US (48 state) address.
Haltech Platinum 2000 ECU w/ Flying Lead Harness (auto spec wiring, long), 3 bar gm map sensor and Air Temp Sensor.
$1580
$2200 w/display dash
$2450 w/display dash & wideband
Haltech Platinum 2000 ECU w/ RB Patch Harness, 3 bar gm map sensor and Air Temp Sensor.
$1580
IQ3 Display Dash add on to kit
$688
IQ3 Logging Dash add on to kit
$1420
Haltech Single Channel wide band add on to kit
$230
prices will incease by roughly 400$ after the end of the month due to currency exchange rates
