Just wanted to share my new 350Z SEMA car with a 2JZ Swap.
I was sponsored by 2JZSWAP.COM and Tech2Motorsports.com for the 2JZ swap kit and Enkei provided me the one of a kind wheels and a spot in the Enkei booth at SEMA. Here are the specs on the car.
2JZSWAP 2JZ Swap kit
2JZSWAP conversion Harness
2JZSWAP Radiator
2JZSWAP Intercooler Kit
HKS F-Con V Pro
HKS Fuel Rail
HKS SSQV BOV
HKS EVC 6 Boost controller
HKS Cam Gears
HKS exhaust
TRD Oil Cap
PLX R500 Wideband 02 meter
APR GTC 2000 Dry carbon Wing
APR Carbon Radiator Plate
NISMO OEM Body Kit
Custom LED tail Lights
Turbonetics T64 Ball Bearing Turbo
Turbonetics Wastegate
Samco Couplings
Turbonetics T bolt clamps
Supra TT fuel Pump
Venom Fuel Pressure Regular
Russal Fuel lines and fittings
RC 750CC Injectors
Setrab Oil Cooler
Ceramic Coated intake and exhaust manifolds by FRP
Flex-a-lite Fans
BMC CDA Intake
Dry Carbon Spark Plug Cover
Cusco Zero2R Coilovers
Cusco Front Upper Control Arms
Cusco Rear Camber Arms
Cusco Rear Traction Rods
Cusco Rear Toe Rod
Cusco Rear Sway Bar
Cusco Front Strut Bar
Cusco Oil Catch Can
Cusco Radiator Cap
Sparco Seats
Sparco Steering Wheel
Sparco Seat Brackets and sliders
Momo Steering Wheel Hub
ARC Amplifer
ARC Component Speakers
ARC Subwoofers
Kenwood Navigation
Custom Fiberglass Sub Enclosure
Enkei 20 Inch wheels
Yokahoma Advan Tires
Project Mu 14 inch Big Brake Kit
These are a few pictures of the build of the car showing from the beginning of the build to the completed car.
First we stripped out everything from the engine bay.
Including the the bumper/radiator support.
Here is some pictures showing the room the JZ has in the new chassis.
Exhaust side.
Intake side.
Ceramic coated exhaust manifold.
Ceramic coated intake manifold/lower runners and throttle body.
Plenty of room for the turbo.
Intercooler installed
New look, powder coated valve covers, dry carbon spark plug cover and timing gear cover.
Project Mu brakes with Cusco coil overs and upper control arm.
The interior was stripped for full audio install and other goodies .
New subs installed with 5 channel amp.
Sparco Seats.
Sparco Steering whee, New Kenwood head unit, PLX Wideband, EGT, Knock, G-force and power meter.
Completed engine.
Check out the new paint!
Front stance with brakes.
Rear stance.
Finished product.
A Few SEMA Show Shots...
