        mlebherz
                Posts66
Everything posted by mlebherz
	hello all! long story short, i have 1973 Z with a rb26 swap using an aem infinity and a wiring specialties harness. no matter what i try i cannot get the motor to fire up on this ecu. it keeps throwing crank timing errors and the timing is all over the place. with the old mine's ecu on the same harness it runs and drives just fine until one day while driving my alt belt snapped taking the CAS pigtail and grounding reference voltage frying the mine's ecu. after fixing the harness now i am stuck trying to figure out the issue with the AEM. so far i have bought a new harness from wiring specialties specifically for the AEM, tried 3 different CAS units, swapped to a ross crank trigger setup (which helped slightly), sent the infinity back to AEM for testing and have pulled out all of my hair. i have a forum open with AEM (https://www.aemelectronics.com/forum/rb26-crank-timing-error-0-1) but have not had any success. maybe someone here has experienced something similar to this with an rb before, i am open to any ideas at this point and appreciate any help i can get! thank you for any input !
	From the album: gas tank restoration had to bed the fuel sending arm slightly to accommodate the pool noodle. did not effect operation
	From the album: gas tank restoration snapped a pic before i bolted it down. kit was very easy to install, only took maybe 2 hours. all parts are included in kit
