mlebherz
Everything posted by mlebherz
  1. From the album: gas tank restoration
    test fit to make sure the fuel pump bracket does not touch bottom of pool noodle. the pump needs room for filter to fit at the lowest point possible with binding
  2. From the album: gas tank restoration
    the goal is the have the rubber sock touching the bottom of the tank but not scrunched up, cut the noodle to size
  3. From the album: gas tank restoration
    drilled a large hole in the top of the tank and inserted studded ring on the inside
  4. mlebherz
    dash resoration
    dash has three bad cracks in it, time to try my hand at this fix
  5. mlebherz
    final product
    From the album: dash resoration
    it looks pretty good, but the paint is fairly brittle once dry. if i ever have it out again i will do a alcantara wrap
  6. mlebherz
    wiring sux
  7. mlebherz
    fit new guages
    was originally going to buy defi gauges, but.. the wallet said no. settled for speed hut guages, the quality was fantastic and i have no regrets. they look great
  8. mlebherz
    painted
    used a black textured pain and coated dash 8-10 times. let set for 2 days
  9. From the album: dash resoration
    followed a tutorial on the forum, opened cracks and filled with a windshield urethane. make sure to leave a little space for bondo, do not completely fill crack
  10. mlebherz
    re-furbished head
    From the album: 73z journey
    after many hours of polishing and grinding the head is done. specs - stock cams - tomei cam gears - obx tubular manifolds (few touch up welds) - rb25 cam covers - spool head oil drain - oil restrictor pill
  11. mlebherz
    purty
  12. From the album: 73z journey
    i cant recall ever purchasing any part that was a beautiful to look at and well made than these rods and pistons. they were all within .7 of a gram from lightest to heaviest
  13. From the album: 73z journey
    you are not going to fail on me again you little sh*t
  14. mlebherz
    new block
    <p>had cylinder walls cement reinforced, sent to machine shop for thorough go-over and touch-up</p>
  15. From the album: 73z journey
    even if you think you have checked everything, life has a way of proving you wrong. oil pump failed after 3rd drive. i was gentle and had to resist the temptation but... sigh, it happened anyway
  16. From the album: 73z journey
    was driving along and heard same sort of noise as the first motor failure
  17. mlebherz
    another angle
  18. mlebherz
    final fit
    motor finally in after much blood sweat and tears
  19. From the album: 73z journey
    <p>solution was to but rb25 rocker covers and remove the pcv internals and add a external oil/air seperator</p>
  20. mlebherz
    test fit
