pahardy
Everything posted by pahardy
  1. I had a hard time removing the air from a new clutch master cylinder from Auto Zone Part # 11795 on a 1977 280Z. To start with the new push rod was 1/2" shorter then the original. I replaced the rod with the one from the original, set at 5" from bolt seat of cylinder to Ajuster pin hole center, same length as it was when removed. I had the play needed at the top of peddle but it appeared to me that the peddle was bottoming out before the cylinder was fully depressed. So I turned the ajuster almost all the way out to assure the cylinder was being fully depressed. That solve the bleeding problem for me. I then adjusted the push rod to a point that every thing worked like it should, about 5 1/4" +-. A 20 minute job turned into an eternity.
