I installed megasquirt 2 on my l28et and i have had trouble getting the engine to stay on and idle. It will turn on and run for about 15 seconds going from lean to rich but it will eventually shut off. If i give it any throttle at all it will kill the engine faster or make it sputter. Is this just an issue with not enough fuel or something more, I also try to set the ignition timing on tunerstudio to be the same as on the timing cover on the engine. When the advance on tunerstudio is at 12 degrees matching with the timing cover on the engine, it wont start at all but when i start adjusting the timing the complete opposite way then the engine will start. I am using a timing light with the engine cranking and injectors unplugged to check the timing because it was jumping too much with the injectors plugged in.
