jjslade
Everything posted by jjslade
How LOW is your Z... and how driveable is it
jjslade replied to jjslade's topic in S30 Series - 240z, 260z, 280z
At the moment i'd say the lowest part is about 3.5" from the floor, i'm not into that stanced look whatsoever, but do like fairly low cars. I'm currently restoring it so I have never driven it, so was just wondering where abouts people had their ride height set. -
Help diagnosing large amounts of white smoke coming out the exhaust
jjslade replied to jjslade's topic in Nissan L6 Forum
Here is a video of it running if it helps, idling at about 1000 rpm, and the smoke is quite a bit more white in person -
jjslade posted a topic in S30 Series - 240z, 260z, 280z
Just seeing how much i can reasonably lower mine, is 2 inches between the chassis rails and floor too low? -
So i have done a compression test 1- 100 2- 95 3- 90 4- 95 5-90 6-90 So very low. As i said, it has a brand new head gasket, so could this indicate all the rings are gone? I also had to re grind all new valves in as 10 of them were bent, so perhaps I haven't done it well enough as it was my first time Any other help would be very much appreciated -
Haha may be a British term, just means very very rough. I will do a compression test and see what results that yields -
Hi there,i've got a 260z with roundtops on, and it idles like a bag of spanners, and emits a ridiculous amount of white smoke out the back. Normally you would think this would be a blown headgasket, but it is a brand new headgasket, torqued down correctly. I have even tried draining all the water from the system and starting it with absolutely no coolant in for a short period, but with the same cloud of white smoke. What else could this be? a warped head maybe, or vacuum leak? Really getting to my wits end with it now.
Hi there, I have a 260z with the following cam, 284 advertised duration....210 at .050 duration with .435 lift on 109 degree LSA, would you guys reccomend the 40 or 45 triple webbers? and also would the stock mechanical fuel pump be adequate? Thanks
with this setup current my SU’s are cranked all the way to the top, idle screws set as low as possible, and it’s still idling at 2000rpm and incredibly rich, so i’m thinking when i ordered a carb rebuild kit i bought the wrong needle? could someone please recommend me an appropriate needle for this setup? Kind regards
Yeah it's Brian i've been emailing, had some back and forth contact but i've been waiting over a month for a shipping quote
I've been waiting for a shipping quote for nearly a month now, had communication but i'm not sure why it's taking this long
Hi there, So I had a bit of a problem with my engine and now need and new camshaft, cam sprocket and valves. I've been looking online for parts and come across this cam for a good price: https://www.ebay.co.uk/itm/DATSUN-240-Z-PERFORMANCE-CAMSHAFT-L24/223560592221 Do i need to change anything else in the engine to fit this? and how aggresive is it? Thanks
Thanks for the help guys, the sprocket had just come loose, gonna have to take the head off and change some, if not all the valves.
So i was trying to get the car started and heard it was making no compression, so i did a compression test and confirmed that. I took the cam cover off and saw that when i was turning the engine over the cam gear was moving but the camshaft itself wasnt, the camshaft does move using some vice grips, and i know the engine isn't seized. I'm thinking either the woodruff key has sheared off, or the camshaft has snapped under the first cap. What do you guys think? IMG_8170.MOV IMG_8169.MOV
