adsdsasdasdasda
Location
america
Recent Profile Visitors
adsdsasdasdasda's Achievements
Hey everyone, I'm in the middle of rebuilding the L28 in my '81 280zx 2+2 and I've hit a brick wall. I'm trying to get the oil pan and the lower engine block/upper pan (the big cast aluminum piece) off, and it will not budge. I'm 100% sure I've removed all the bolts I can see, but it's sealed on there like it's welded. Here's what I've tried so far: Engine Oil Pan Separator Tool: Did a bit but not a lot. Razor Blade: I'm trying to work a razor in, but it's taking forever and barely making progress. I'm worried I'll be here for days. WD-40 : Thought that i could break up the seal/glue with it and... nothing Tap the side of the pan with a mallet to shock the seal; nothing I'm getting frustrated and don't want to start prying and gouge the mating surfaces. Am I missing something obvious? Are there hidden boltsthat I'm not seeing? What's the magic trick to breaking the seal on this RTV from hell? Any tips, tricks, or tools you've used for this specific job would be a huge help. Thanks!
Hey folks trying to take out the drive shaft so i can take out my transmission and engine. been trying to throw a wrench on the nut (at the end) and use a screwdrive to turn the shaft so the bolts can loosen up. how ever this isnt working. tried pb blaster, wd40, wd40 penetrate. next thing ill try is heat but im worried about the grease, oils from earlier and the break lines near by. alternatively im thinking about grinding off the nuts but not sure if there are any other ideas. please lmk! P.S. I started stripping the nut head. https://imgur.com/a/w9CVTiL
1981 280zx wont start up like it use to (reliably)
adsdsasdasdasda replied to adsdsasdasdasda's topic in S130 Series - 280ZX
well when its cool seems like it has little to no issues. -
no it charges it it, stable voltage when off, turning on, and when on. 12.8v , 9-10v , 13.6-14.2v respectfully. -
So I do have power so dont think its that, stay around 10. I think its the distributor, other have said the ignition module on the distributor. When my car wasnt turning on, as I described above, I noticed that that component seemed to be quite hot (like a sufficated laptop). And that there would be not spark/signal to the ignition wire(s). when the car was able to start at some cooler temps then spark/signal was sent to the wires. -
I got my car one year ago and it's a 1981 280ZX 2 plus 2 non-turbo Edition. The car went and rode very well for the first year with only 46 original thousand miles on it. Since then I've made some modifications to it and made it a little my own and added about 10-15k MI to it. The car has worked really well over the last year however in recent times there have been some issues where it isn't so reliable all of a sudden. I worked on some dash upgrades a few days ago and got new speakers. It sounded very well and was very pleasant but 5 days later problems started to rise like no other. I drove to a place about 20 minutes away from my house where I volunteer and I noticed that my car wouldn't turn on / engage like it usually would. So I turned the key a few times and was lucky enough to get it working and went to the next location which was 5 minutes away. At this point in time, my car once again wouldn't turn on after it was shut off and my battery didn't have a good level maybe 9 to 10 volts when I tried to start it up again (multimeter). For the next 20-30 mins I tried again and again, out of nowhere got it to start up, and went home. I gave the car a two-hour or so rest and then went to AutoZone, it started up perfectly fine and didn't really have any issues which was interesting. I got my battery tested they said it was essentially shot and I needed a new one in which case I got a new one. I bought the best one, a duralast Gold, and I went home and everything seemed fine. However, I was curious to try it out (starting my car again) and see if my car would start up again after I turned it off it didn't. At this point, I knew there was a large or underlying problem that I couldn't pinpoint so I started to chip at it. Parasitic draw/Battery theory My initial thought was the initial battery was drained due to parasitic draw. I tested it by taking out all of the fuses of the connections wires (chrisfix's video), yet I didn't see any change/ Outrageous DC amperage (stayed at 0). Then throughout the entire night, I tested my battery level and notice it was at a steady 12.8 V at 1-hour intervals for 5-6 hours. At which point I realized it's probably not a battery issue. Alternator theory Now you might ask well maybe it's an issue with an alternator however I did get the car to start every once in a while out of pure luck at which point I would test out the and it would read anywhere from 13.6V to 14.2V constantly never going below that. And I could drive around as soon as I could get the car and it would not turn off no matter what (as far as I suspect I've driven anywhere between 15 to 20 minutes every time) Starter theory This leaves us with the starter being the possible culprit for this entire issue however I doubt that's the issue. Every time I turn the key the starter would crank and you would hear the noise of a car starting up or trying to. Now one important/interesting thing to point out was when I did get my battery checked the following day after all of these issues the auto port did say that there was not enough cranking RPM. However, I've gotten my car to start up many times since then. Other theory (distributor) At this point, I was really confused and I had no idea what could be going wrong as the problem persisted 50%-75% of the time. I then contacted my mechanic and he said it could be a possible issue with the distributor where things could have weird issues but I'm not too sure. When I do have the car running, I drive it like normal and I drive fast and rev high at some points of my drive. This caused no issues so I'm doubting that this is a spark plug issue. I'm not too sure if it's a distributor issue however I'm doubting spark plugs to some extent and thus I'm also the distributor. Other interesting facts/things that I noticed Something that I thought about when diagnosing this problem was an engine needs fuel, air, and ignition to start up. I was able to hear my fuel pump so I'm pretty sure my fuel was there however not too sure about ignition as I'm going to take a closer look at that tomorrow (sparkplugs). The only thing is I haven't gotten a new air filter and my car needs a new one because it's a little dirty, I wouldn't say horrid but dirty. It seems like my car goes back to regular/driveable mode after I give it some time to cool down and essentially relax, but that has to be after every time I drive, even if I drive for 5 minutes around the block (no speeding, etc). Also at one point the car would crank and engage and then die soon after (like 1 sec after) I did have my multimeter hooked on the terminals but I don't know if that would cause that issue. I have a video that I can post of that happening and the car not starting. Video of the car starting up with a little issue Video of the car staring and dying soon after (with multimeters touching terminals) Any other ideas on what could be causing this issue? What do you suggest I try next?
I currently own a 1981 280zx, the car is in pretty pristine condition. However, I want to protect my Dash from the Sun and other things. Currently, there are no cracks or any issues with my Dash and I was thinking of buying a dash cap pacifically the one on the Z store. However, it says I would need to apply adhesive to my current Dash and the dash cap. Would I ever be able to remove that adhesive without any issues or would this be a permanent overlay? Also, my current dash is blue and want a black interior, dont want to re-paint it and I may one day want to go back to the original so the option is very tempting. https://www.ebay.com/itm/334214953109?epid=15024529959&hash=item4dd0c37895:g:UxcAAOSwJL1hjSyc https://www.thezstore.com/page/TZS/PROD/classic08d04/50-2023
I think i have a small exhaust leak, but ty
So I've been riding my 1981 280zx around and for the most part, it's good. but there is an issue at weird and spontaneous times. I hear crackling going off when I drive. The best way I can explain it is it sounds like small sparks of electricity/leaves crumbling. I thought it was just debris at first but then I noticed it happens at times when I rev my engine. the engine does not overheat, it stays between 120 and the midpoint (190). Nothing is leaking from the car, I had UV in the coolant and there are no leaks. I check my coolant levels and they seem to be consistent. any idea what this could be?
Hey, guys recently I have noticed that my car had been leaking coolant. Luckily I caught it early and there is no damage but I want to get this fixed asap! I have a 1981 280zx and I can't figure out what this part/pipe is. Any help would be helpful full, the image below: P.S. If you find any diagrams that have this part please post them, I couldn't find any <3
I recently got a 1981 280ZX Datsun. The car runs well and I love it, though I wanted to make some upgrades/mods to it, specifically the start and locks of the car. I essentially want to have remote locking and starting of a car. I have found very few kits that do both, most kits either lock or start with the remote. I could have two remotes but that doesn't seem logical to me. I'm very new to the realm of cars and especially electronic work on cars however, I do have friends that are willing to help me with this stuff, any suggestions on how I can incorporate both of them into 1 remote? Thank you
