First things first, my car is a Base, completely non optioned '79 5-speed 2 seater built in 10/78. All of my electrical components aside from the stereo are original/stock and unmodified.
The issue that I just started having is my 15A glass fuses for the "Clear Tail" circuit of the fuse box blows IMMEDIATELY and VIOLENTLY (Voltage dips to about 10V, big spark, sometimes with an audible pop) upon turning the headlight switch to either "Park" or "ON". When this happens, I lose every single light on the vehicle aside from the high beams, Brake lights and the interior dome lights.
According to the FSM, this circuit sends power to "Light warning lamp, Illumination lamp, license plate lamp, side marker lamp, clearance lamp, tail lamp" The first thing I did to kick off diagnosis was pull the column covers off, and inspect the connectors that go to the light switch/stalk. To my surprise, they all looked to be in excellent shape with absolutely no signs of melting or corrosion. Next, I started the process of elimination. I unplugged every light on the parking light circuit including: Tail lights, side markers, front turn signals, and the dash dimmer switch. I removed each bulb. I did not unplug the license plate lights because they didn't work to begin with. The rear tail light sockets had some slight corrosion (thin layer of white powder substance) but other than that, the sockets looked to be in perfect shape.
Once I did this, I popped a new fuse in, turned the switch, and results were exactly the same. The voltage meter dipped followed by a Big spark, and a pop of the fuse.
Out of all the Six Z's and ZX's I've owned, I've never had any issue up until this point with Fuses popping so suddenly and consistently. I am looking for advice on how to continue with my diagnosis. Is there a possibility that a relay is causing the short? Could the Fuse box itself be going bad? (No other fuse terminals have this issue) Or have I missed something obvious?
