kaibiagi
4
Everything posted by kaibiagi
Anyone ever used Gyraline DIY alignment tool?
kaibiagi replied to kaibiagi's topic in Brakes, Wheels, Suspension and Chassis
@calZ@manimal@jhm @Sam Henao So I finally got around to testing it this weekend and it's bad news. The numbers I'm getting in both thrust align and body align mode are not consistent at all, sometimes being over 2 degrees off measuring back to back with the same method. I tried probably about 5 times with no real consistency in the results. I don't think I messed up the method as I followed the instructional videos on the website exactly. Unfortunately, I'll have to take my car to an alignment shop and let them give it a proper alignment. -
I haven't tried it yet because I had to take the dash out so I couldn't drive it to a flat surface but I can test it out this weekend. -
Late response, but it may be useful for someone else. Manuel Auto Body and Custom Collision in Vallejo, CA did my (Capital Metal Works) frame rails for $1500. Seems like he did a good job, they are definitely on there pretty good. There was basically no wait time when I had it done and he had it done in like two days spot on the original estimate. I would imagine he could probably do floor pans too. The other place I would recommend is Driven Garage in Hayward. They tuned my carbs and their shop was very impressive. They do complete restorations, including body work. They could definitely do floor pans, but it may be on the pricier side.
Hey guys, my turn signals + hazards recently stopped working on my 280z. They were working fine until I unplugged all the switches from the center console while I was test fitting my new radio plate I made. I took a drive after this and lo and behold, no signals. I then realized I forgot to plug everything back in, so I did that and still no signals??? The signals were working perfectly before this. Additionally, the brake lamp in the speedometer no longer lights up. Hazards also do not work. I tried putting another flasher in because I happened to have one on hand and it couldn't hurt to try it, which did not fix the issue. The turn signal switch and hazard switch were taken apart and cleaned less than a year earlier when I was facing a similar issue (the problem was they weren't plugged in), so they should be in good shape. I took the hazard switch apart again just to check and it seems to look fine still. I tried to check if the hazard switch was getting power with a multimeter and I don't believe it is. I touched basically every wire that goes to it beside the light wires (not exposed) and everything read 0 volts. I do not really know how to use a multimeter though so take that with a grain of salt. Looking at the FSM diagram BE-12, I believe the issue probably lies somewhere before the hazard switch? The fuses look fine as far as I can tell, and were all replaced less than a year ago so they aren't old. Fusible links look fine as well. Here is what works and what doesn't: Works: All running lights (side markers, headlights, tail lights), map light, AC console backlighting, center console switch lights (including hazard switch light) Does not work: All gauge lights (they already did not work), speedo brake light, turn signals (no flasher click or dash turn signal indicator either), hazards, windshield wipers and washer motor (might as well throw that in) Anyone have any advice for me? I will attach a photo of BE-12 along with a connector I found that I cannot find where it plugs in. The connector has two wires, one green with a white stripe and one red with a green stripe. It has a T shaped connector. I don't see where it plugs in, but I don't think it's related to my turn signal issue because I don't see anything like it in BE-12. I think it may be part of the meter illumination light system. My current plan is to rip the center console out at least, possibly the dash and root around down there until I hopefully see a smoking gun. If there are any typical failure points I should check, let me know. Thanks for the help!
It's a 76 280z. I've seen the scalloped ones, but it seems to be impossible to find OEM style replacements from my searching. There is no gap, but they are definitely hard. I'm pretty confident the source of my clunk is the front differential mount, because it seems totally busted from what I can see from the bottom. My plan is to buy these rubber spacers on Amazon and drill the inner diameter out to 22mm to fit the end of the mustache bar bushing. Then I would drill holes horizontally through it to make it a little softer to kinda simulate the stock part. I have new metal washers with my poly bushings, so I'll just throw those on and hopefully call it a day.
@NewZedThanks, i'll reuse them then. I bought the stock style one from ZCarDepot, so it should be here in a couple days. I'll throw that in and see how it affects things. If it still clunks, maybe I'll try buying the mount from TechnoVersions. I'll attach some pics of the puck things. They go on top of and below the bushing itself, and are surrounded by metal washers. 3 of the 4 pucks appear to be rock hard rubber, and have the washer stuck to them. The other one seems to be a poly material (the washer fell off of it when I took it off. From my research online, it appears these are not stock? I looked and found some wavy looking rubber washers on some cars, seemingly for the purpose of NVH reduction. My guess is that a previous owner replaced those with these solid rubber ones at some point. I might just go to a Home Depot and see if I can find a similar size replacement for these, and maybe drill holes in them to simulate the wavyness of the OEM ones and help reduce NVH. Thanks for the tip about removing the mustache bar bushings. It sounds like I won't be doing that, but that would be much easier.
Hey, stupid question but do these rubber mustache bushings look ok to reuse? I was installing my new t3 RCAs and eibach springs and decided to check all the diff mounts while I was there. Not sure if this is ok to keep using. I don't really want to use poly and I can't find any new rubber bushings online. There is some cracking around the edges but it looks ok-ish? The 4 puck things are hard as rocks and chipping a bit on the sides (I can get pics of those too if necessary). Not the end of the world if I have to switch to poly, but I'd love to avoid breaking out the Sawzall and torch if I don't have to. Let me know what you think. Thanks. Edit: on another note, my front diff mount is absolutely destroyed. I will be replacing it with a new rubber mount. Is the RT style mount from TechnoVersions needed/recommended in addition to a new stock mount or would I be good with just a new stock mount? It's just a stock R180 + L28, so no big power or anything. I already have to wait a week for the stock mount to come in, so everyone in my dorm parking lot is already gonna think I'm a dumbass while my car is on jack stands for a week. Also, if I do end up switching to poly, would something like a rubber washer or sound deadening material on top be a good idea to try to reduce some of the additional NVH? Again, thanks for the help.
I just bought one and it should be here in about a week. I'll let you guys know how it ends up working for me. -
@jhm Yeah it seems like it would be really useful for making quick alignment changes without having to bring it to a shop and having them do it for you. Save a lot of money too ofc. Looking at their website, they have a lot of testing data which looks pretty promising. Like you said though, I would prefer to see some reviews and data from users, not just the manufacturer. Like Sam said, you buy a 99 cent token for each alignment you want to do. I might just buy one since its only $40 and then take it to a shop to get an alignment check and see how accurate it is. @Sam Henao This looks really cool, but I do have some concerns about the pricing structure in the future. Are there any plans to get rid of or increase the price of the tokens? I would hate to buy it and then have the pricing model be switched to a subscription system or something. What exactly do you mean by most advanced algorithm? Thanks for responding, this looks like an awesome tool. -
I got an ad for this gyraline thing on Instagram which advertises the ability to do DIY alignments seemingly using your phones gyroscopic sensors. It honestly looks super sweet, but I haven't heard of it before and there doesn't seem to be too much info out on it so I thought I'd ask if any of you guys have any experience with this or something similar. With how often I screw around with the suspension, this would probably save me a lot of money if it really works well. https://gyraline.com/?srsltid=AfmBOoonzfGKwgL5wLRT_Wl5WHc9hYeCTI1hTJwmyUHGzwQpuW70pYvN
cant figure out steering clunk/pop
Thanks for the suggestion. The issue happens only when driving the car. I can turn the wheel all I want when the car is stationary and there will be zero noises. I really have no idea why it would only happen while its moving. I don't think there would be any more stress on the steering system while moving, if anything it should be less right? That line of logic would point towards the suspension but I don't see anything out of the ordinary there. -
I have not checked the front cross member to frame bolts. Thanks for the suggestion, I will check that out. The bushings on the T/C rods are new and tight, I put them in myself. However, the washer is missing from the back of the passenger side. I got a new one and will be replacing that. I will also replace front strut mounts and bearings since I have the parts for it and its pretty easy to do while I've already got it jacked up. I think I'll just order a new rack and pinion, because I think that may be the issue. It used to grind, which makes me think it probably wore something out in there due to lack of lubrication or something. -
I just replaced the steering coupler with a polyurethane one from Energy Suspension, and while it no longer moves like in the video, there is still a clunking noise from the front when turning while in motion (not at a stop). All I can really think of at this point is inner tie rods and front strut bearings. Maybe steering rack itself is loose and clunking? -
Drum Brake Lower Spring hitting hub
update for anyone in the future who may have the same problem. The wheel cylinder was put in the wrong way by the previous owner. I attempted to reassemble the brakes how it came apart, but the way it was installed before was wrong. Putting in a new wheel cylinder in the correct orientation solved the problem.- 1 reply
- 1
I haven't done anything yet. The car is actually in storage for the summer at my college and I'm on a ship for the entire summer, so it's gonna be like a first thing as soon as I get back. Thanks for the tips, I will certainly do that. I'm also glad it looks cheap and easy, its too bad I found it after replacing basically all the wear components on the front end of the car though haha. They needed to be replaced anyway though, even if they weren't the source of the noise. -
Awesome, thanks. I'm pretty sure I actually already have a poly one that came with my complete bushing kit, so I'll just pop that in at some point. -
Here is a video of me moving the steering coupler bushing thing around. Is this amount of play normal or should I investigate further? Sorry about the stupid questions, im fairly new to this still. IMG_8654.MOV -
Can't imagine its that, since I torqued them to spec and used blue thread locker when I was replacing the ball joints and tie rod ends, but ill give it a look for sure. -
Gotcha, I'll try removing one end link tomorrow and see how that effects things. I've removed it before when I was replacing the bushings and there is no damage to the frame where it attachs, rust or rips. Not sure if its an aftermarket bar or not. For some reason I only have a front sway bar, no rear. As for the rag joint, I believe its been replaced with polyurethane by the previous owner. I'm not 100% sure its poly, but the rag joint is definitely in good condition just from looking at it. All good, im not too worried about that but I figured I might as well ask while im here. -
kaibiagi posted a topic in Brakes, Wheels, Suspension and Chassis
Hey everyone, just looking for some advice on this problem my cars been having. 1976 280z, the steering will make a pop/clunk noise when I turn either right or left. Sometimes I dont have to turn too much to get it to clunk, and sometimes I have to turn the wheel almost completely over. It will only do this when the car is moving, and only at low speeds as far as I can tell. (It totally might do it at high speeds but i havent turned the wheel enough for it to do so at high speeds). If I turn the steering wheel from lock to lock while the car is not moving, there are no problems and everything functions normally, no matter whether the front wheels are on the ground or in the air. I have already replaced front wheel bearings (NTN), outer tie rods (Moog), ball joints (Moog), sway bar bushings and end links (poly), tc rod bushing (rubber) all other bushings are poly and in good shape. I don't think its the inner tie rods because it only happens when the car is moving. I'm thinking maybe I could have somehow fucked things up on the swayer (although it looks fine), so I might try to take that off completely and see if that affects anything. The other thing i could see it being is a loose bolt or something somewhere causing this, because there have been many other things loose on my car causing me issues. Anyone got any other ideas/advice? It could totally be something obvious that I'm just overlooking somehow. Other random thing: does anyone know where this blue wire plugs into and what the fusible link looking things are for in this picture? They are under the driver side dash and I can't find where to plug them in. My dash lights don't work and I'm guessing this is probably why. Can't seem to figure it out by looking at the wiring diagram.IMG_8650.pdf Thanks for the help! repost since I accidentally posted in faqs -
How to unscrew stuck outer tie rod??
It 100% fits completely normal. It honestly seems to make makes more sense to have it that way because the then the LCA-Ball joint bolts are facing downwards instead of up like they are with the corredt orientation. But yeah, there is no forcing anything, it fits right up like normal like that. I ended up installing the ball joints the regular way (on top), as shown in the FSM. And as for the stuck tie rod that was my original problem, I went to Harbor freight, bought a 36 inch pipe wrench, and put my feet on it. Got it to come off relatively easily that way. Threads werent corroded or damaged at all, it was just ridiculously tight. Thanks for the help -
The first picture,MG 7884, is how I've seen it installed in other peoples youtube videos and how I think it is installed in the FSM. The baseplate is on top of the control arm. The second picture, IMG 7885, is how it was installed in my car on both sides. The baseplate is on the underside of the control arm and the ball joint sticks through the hole. I have not seen this anywhere else Everything seemed to work fine, except for a clunk when turning at low speeds. I believe this was due to the tie rod though, unrelated to the ball joint. I just figured I'd replace the ball joints anyway while I was there since they are cheap. -
FSM was the first place I checked, I just wanted to double check since the picture is kind of difficult to see whether the baseplate of the ball joint is top or bottom. It looks like its on top but I'm not 100% sure. I'm assuming that its supposed be on top and the whoever did this previously is just a dumbass, because I've seen a lot of stuff on this car done wrong. Somehow the wheel cylinders in the drum brakes was put in upside down and backwards and it still worked, so when I went to replace it I was super confused. -
Also, are the ball joints supposed to go on top of or below the control arm? Every video I've seen has them on top of the control arm, but on my car they are below and sticking through the big hole for some reason. Is this just some previous owner dumbassery or is that ok? 1976 280z.
