Over30S130
About Over30S130
- Birthday 08/21/1968
Gender
Not Telling
Location
East Alabama
Over30S130's Achievements
0
Strange Hesitation/Sputtering Issue. 78 Z
Over30S130 replied to Bates_'s topic in Trouble Shooting / General Engine
Old thread, but same thing seemed to work for me. Have had to tap ECU with my foot on a few occasions during a couple of months-so far gone the longest without any issues-about a month now. Even tapped it with foot on the gas to make sure that's what was seeming to fix it. Not sure if the issue lies in the plug connections, grounds, or the inner-workings of the ECU. Who cares for right now. -
'82 Turbo sputtering issues
Over30S130 replied to Over30S130's topic in Trouble Shooting / General Engine
Thanks for the info. May have to end up doing the same if the problems persistently reoccur, but doing OK at the moment. -
Like them already!
Desperatley need to see pics. Not enough of the newer line of the XXR wheels posted, especially wider widths and on a 280ZX which is what I have. Post pics as soon as you guys get them mounted on your cars. Be sure to mention size of wheel/tire and offset/backspace and any size spacer used and also anything different you would have done. Thanks.
Update-hope this might help someone a little. Had previously fixed this issue by accident by just disconnecting the cables at the ECU and just plugging them back in. The problem has resurfaced again. Sputtering on initial take off even with light throttle. Releasing gas pedal and reapplying slowly seemed to get through this, but when trying to accelerate, when just starting to boost or at zero vacuum, power would hit a wall. When this last happened, I let off the gas and bumped the panel where the ECU is located with my foot and reapplied the gas and what do you know, all power is back. Problem not solved I know, but maybe I am atleast in the right location on this issue. -
My '82 Turbo diesels after ignition is cut off
Got to thinking more about this one. When I turn the ignition key to the off position, the the warning lights appear on the display as they do when cranking, but do not immediatley turn off. I can hear the fuel pump still running while these lights are still on for a second or two and then the engine shuts down slowly after fuel pump is has stopped,lights go off and then door lock opens. Still thinking this might have something to do with PO's install of alarm-disabled right now by PO-atleast the horn is that I know of, but the alarm light on windsheild pillar stays on while car is off. I beleive it is a VIPER alarm. Any ideas or comments or just leave AS IS? -
It's worth a try and easy enough to do. If it runs better, would that mean my O2 sensor needs replacing rather than just run with it disconnected? I kinda want to get the best MPG when I can-nevermind, this is my Turbo car-hard to keep foot out of this one. -
When I turn my ignition switch off the engine keeps running for about 2 seconds. I don't think it is actually dieseling as to me, dieseling is whereby the engine almost quits then keeps going a time or two-usually with some knocking as well. Mine just has a delay and then just slowly quits. Just wondering if other stock turbo ZXs do the same thing, if not, could it be due to having an alarm system wired in or what?
Just wondering if anyone has ever damaged their front mount oil cooler by running to far up on a curb, etc. when parking. I haven't looked at it in close detail, but just wondering if it is set back enough sothat the front wheels will hit the curb first, providing that the front grill clears. Sure would hate to damage this if I can help it, by being a little extra careful when parking.
Very important update-I haven't driven my car in the past few days trying to research the CHTS. As mentioned earlier, I did a tune up and as soon as I let it off the ramps and cranked it, it would not full throttle up-it would only bog and pop through the AFM if I held the throttlr down long enough. If I disconnected the CHTS, it would rev fine, but would lose idle and stall and it would not restart without reconnecting the CHTS. I tried this morning to take a stab at diagnostics with a meter and my FSM. I checked both my old and new CHTS in ambient temp(supposed to check in controlled water) and both were reading about 4 ohms which was in spec with the book for a temp. between 20 degrees F and 68 degrees F-outside temp. was about 50 degrees. I then check at the connector and got nothing???? I proceeded to disconnect and reconnect the 3 connections at the ECM, but I wanted to check #23 to ground for the CHTS since I did not get a reading at the connector. My probes were not small enough to get into the connector-oh well, so much for that! Before reconnecting the battery, I disconnected the connector at the decelleration device,I forget the acronym at the moment. I did this because I was having idling issues before the tune up. I started her up and everthing is fine now. Idle is at 750RPM and revs full throttle with no problems and holds idle afterwards as well! Go figure. I have read it here before and now cannot reitterate it enough, on cars this old, it pays to disconnect and reconnect all connections-especially those that are prime targets and at the ECM. Take it from me, wiggling-disconnecting/reconnecting has solved two of my major problems with this car. Who knows-maybe disconnecting the battery might have helped as this usually works with machinery that I work with and it works for computers by re-booting. Bottom line, however it got fixed I do not know. I am just glad because it was starting to piss my wife off with the purchase of my new found toy of long ago. The only thing I can figure that might have contributed to this whole problem is bumping the connector for the CHTS while installing plugs. The connector itself is cracked and missing clip now, but seems to be making solid connection without. the boot to the connector has a tear, but connection and wires appear to be fine. Hope this helps someone who has this known problem(s) with these cars-I know I'm a happy camper right now!
I havn't because it full throttle revs fine when I disconnect the CHTS-just may die or not keep an idle if remained disconnected. Cannot full throttle the gas from idle with it connected-justs bogs. New plugs were removed and looked OK-clean on one side-brown on the other with no black soot or wet look.
Did a small tune-up since car was recently purchased and could not tell when tune-up had last been done and was also having some slight hesitation/surging/miss??? at normal throttle(fine under boost) and a low and slightly erratic idle. Here is what happened-changed the oil and filter, changed spark plugs to NGK copper U-grooves(gapped to .044)-same brand that was already in prior to tune-up-even indexed the plugs as best possible through trial and error-plug wire orientation verified as well. Changed the fuel filter and blew a little compressed air back through the line to the fuel pump to hopefully clear any possible blockages since fuel pump accasionaly had different sounds/tones at times. Took her off the ramps and started her up fine, but engine would not rev-period. It would sputter,bog, choke etc.-assuming running lean because I saw no black smoke. I disconnected the CHTS and she would FULL THROTTLE rev fine, but when RPMs came back down to idle, the engine would sometimes die and would not crank without re-connecting the CHTS. I thought the fuel pump might need priming, but then why would it rev fine with the CHTS disconnected. I even took all the new plugs back out to check and none of them were wet really. I went out and bought a new CHTS-although it looked slightly different, it looked more like what I had than any other sensor showing at the local auto store-O-Reiley's was the only one that had one or could even get one. The only difference was that the new one had a smaller/shorter part that goes in the head. It came with a washer which was installed-not sure if the brass part of the sensor needs to be directly in contact with the head as the old one had no washer. Started up fine-had better/near normal idle, but still would not rev at all without disconnecting again. I even cleaned the wire harness contacts with spray contact cleaner. I could drive like this I suppose, but I would have to feather the throttle at stop lights to keep from having it die on me and if it did I would probably need it reconnected just to get it started back up or I could leave it connected and not have any power whatsoever, neither of which sounded like viable options. Apparently the problem is not with the CHTS. What caused this change???????? Just wondering if anyone had any first hand ideas without having to go through the whole EFI Bible diagnostic check,
Will '75 Z Auto R200 swap into '82 Turbo Auto
Over30S130 replied to Over30S130's topic in S130 Series - 280ZX
Thanks for the clarification on the Turbo application Brad-Man, that kinda had me confused as well. But,not all NA ZXs had just R180s either, I believe. An '82 I previously owned had a R200. -
Thanks for all the replys guys without getting flamed. I did my searching in those areas prior that were suggested herein, but just wanted to get some more confirmation as who knows, there might be some minor conflicting info. or info. left out on various info. that lists diffy's to model year match ups. Thanks Z2go as that was just the kind of information I was looking for-first hand info. on the '75 Auto diffy. But I know, nothing can take the place of seeing it first hand and verifying for sure at that time. I didn't necessarily want to go with an older R200, especially one that I had to modify-however easy as you make it seem, but this one kind come up suddenly even though I wasn't really in need of one quite yet, but couldn't resist atleast checking into it due to the fact that it was pulled out of a new car and stored. I may have missed this one as his ad is deleted now and I have not heard back again, but atleast I have aquired some very good info. to help in the future. Thanks again.
