tkach
About tkach
- Birthday November 30
tkach's Achievements
0
Thanks! Im glad someone likes it! I tried to use as many aerodynamic enhancements as I could fabricate. Ive got to toss on the headlight covers hopefully this weekend. This project is coming to an end.
its finally all one color! Ill post some more pics of the motor as soon as I can take them. here is the rundown on the car Motor Small Block Chevy 5.7 350Cu In Stock Truck bottom end Hei Distributor with Mallory Internals Accel 300+ Spark Plug Wires Accel Header Shorty Plugs Mallory Hi Fire Ignition box Block Hugger Headers 2 ¼ In Exhaust to Flowmaster Y pipe to a 2 ½ Stainless MagnaFlow Muffler Holly 4510 750 Cfm Carburetor Edlebrock Performer RPM Aluminum Intake Manifold And Matched Camshaft World Sportsmen Heads 2.02intake and 1.6 exhaust Valves 1.6ratio Billet Aluminum Roller Rocker hardened Crane Pushrods and guideplates. 64 CC combustion Chambers 200 runners Optima Red Top Battery Hydraulic lifters 3/8 In Fuel Line Duel Feed from tank to pump All lines from tank to pump and from pump to engine bay are AN Holly Red Electric Fuel Pump Jegs An Billet Aluminum Fuel Filter Black Mountain Precision Billet aluminum underdrive pulleys with 1 inch cog belt. All New accessory Starter Alternator Water pump Fabricated aluminum overflow catch can JTR Aluminum Radiator Mounting Brackets JTR Aluminum Radiator Billet Aluminum Motor Mounts Correct Adapters that allow utilization of stock Datsun Gauges. Oil pressure warning sensor that detects oil pressure/low level conditions and proceeds to shut off fuel pump Drive Line Turbo 400 trans Fresh Rebuild 1 ton chevy end Lokar Dipstick B&M Z gate Shifter Cannon Engineering Driveshaft Custom Slip and spline design with solid Chevy 1 ton ends R200 Rear end with chevy 1 ton end adapter 3.54 gears JTR Speedometer Cable Adapter Polyurethane Differential Bushings. Brakes And Suspension Toyota 4runner Four Piston Calipers Brembo Rotors Polyurethane Steering coupler Polyurethane Sway bar kit Polyurethane Tie Rod Kit Motorsports Auto Rear Strut Tower Brace Body ISMA spoiler Front Air Damn Molded into the body Custom Shaved marker lights Smoked Headlight Covers Custom Vented Hood Custom Shaved wiper grill Smoked Signal lights Vortex Generators Lexan Rear window. Interior New Dash New Carpet B&M Z Gate Shifter
Front Bumper Rear Bumper Hatch Dont need glass or wiper just the hatch itself Rear Strut Bar Cover Drivers Side Rear tailight Drivers Side Rear reverse light
Okay grumpy looking for some tips on my timing. The motor is a 350 stock block and pistons. Ive got some world heads with 2.02 and 1.6 valves 1.6 roller rockers. 1 5/8 block hugger headers Hei dizzy with a mallory hyfire ignition system. My cam is a 278/280 duration. Im running a holly 4150 750cfm carb Eldebrock performer intake manifold. Behind the motor is a turbo400. Just got everything setup looking for a good place to start with my timing.
Got my EZ Wiring harness, got a question
tkach replied to Mycarispurty's topic in Ignition and Electrical
The Ez harness is crap. If I remember correctly the ez harness has a third break light wire that runs to the rear section of the harness just use that. -
For those with engine swapped track day cars...heater vs. seat warmers?
tkach replied to rustrocket's topic in Interior
anybody tried seat heaters im thinking of snagging a pair? -
New Paint, and a TEENY bit of frustration...
tkach replied to YellowFever's topic in Body Kits & Paint
Thanks for the pics of the gas cap looks great aftermarket for a CBR? I may have to copy that look sorry its just too good ! Not only that but where did you find one that matches the curve of the datsun so well? -
Search in the Brakes, Wheels, Suspension and Chassis section and you will find your answer.
Looks amazing! I personally hate the EZ harness, I've had several issues with mine most related to build quality! (of course some related to me) However I would in the future go ahead pay the extra cash and buy the painless!
Looks great do you have any close up pics of the gas cap? -
Well I did some thinking and some calling, and the manufacture recommended some different head gaskets. So I went ahead and ordered them and a far superior intake manifold gasket. Its worth the extra hundred dollars for my piece of mind. At that changing head gaskets wont take that long! In the end grumpy thanks for pointing me in the right direction!
Thanks Grumpy ! Ill tear It down take a look and report my findings! My findings should be conclusive correct IE the pressure exerted on the gaskets/manifold under operating conditions shouldn't yield different results from the standing test correct?
Grumpyvette I hope you can help me with this one (or at least confirm my suspicions). I just finished re-assembling my motor (350 small block I stepped up to some nice dart heads!). As I was filling the radiator with fluid I noticed a small leak coming from the back of my intake manifold (an Edelbrock Performer). I got out my torque wrench and followed the torquing pattern and re-torqued the intake manifold to 25lds. This seemed to stop the leaking. However as I went on filling my radiator I noticed that fluid was disappearing. I went ahead and opened the drain plug on my oil pan and found the fluid! To confirm that I still had some kind of leak I waited until the pan was dry, and then filled my radiator again. To my horror it began leaking again. Now I went hunting for the source of the problem I suspect/ed the intake manifold so I figured I'd try and rule out any other possible problems. So I started with the heads under the assumption that if they had fluid in them they would not be the culprit. So I removed my Temp sensor and I had fluid, ditto for the other side. I'm hoping that rules out the possibility of problems in the heads/head gaskets. After looking at the head gaskets Mr. Gasket #720-101B standard material (When Installed the gaskets I put a coat of gasket glue around all the water passage points both on the head and intake side) . I noticed that the ports around the water jackets have become moist and water soaked, they do not leak externally however they are visibly wet. Now, I am going to go out and buy some better intake manifold gaskets as I believe this is the problem? Is there any way that I can test my manifold itself for leaks? Am I on the right track/ any suggestions ?!
