jmark06
Everything posted by jmark06
Anybody? I'm hoping to get the engine in this weekend so I need to have this done soon. Should the machine shop be able to balance the flywheel independent of the rest of the engine after lightening it?
So they machine shop should just be able to lighten and balance it by itself? What do I tell them, that the engine is "already balanced internally"? I don't want to sound like I don't know what I'm talking about when I go over there and he tells me he doesn't recommend it.
I have a 240mm flywheel that I plan to have lightened and put on my turbo motor. When I called the machine shop they said that in order to balance the flywheel after lightening that I had to break the whole engine down. I've attempted to rebuild the engine mostly by myself b/c of money issues. I did not have the crank turned or balanced and now I'm worried that might be a problem but it wasn't out of tolerance when I pulled it. Am I in trouble now (I kept the same pistons and everyting, just changed bearings and had the head reworked) and can the flywheel be balanced without the rest of the engine?
Bastaad I was thinking about doing exactly what you suggested b/c I've read several of your posts about it. What exactly do you mean by a "heavy duty Daikin PP", like what model vehicle or some part number or something?
I know some of this has been discussed and I've read a lot but I just wanted to ask. Somehow I seem to have LOST my turbo flywheel during engine rebuild, seems hard to do right? Anyway I'm hoping for about 300hp when I finish all the mods I want to do. Should I go to the junkyard and grab another turbo or 2+2 flywheel and have it resurfaced or just get an aluminum one. I won't do a lot of racing mostly just want to be able to beat all the cars on the street around town. So buy another flywheel and have resurfaced ~$100 or just go aluminum ~$300. Is the $200 difference worth it for just driving hard around town and the occasional weekend race. Also I'm planning to get a SPEC clutch. Is it worth the extra money for the stage 2+, it has carbon-kevlar material as apposed to just kevlar for the stage 2. Will it wear better? Thanks for your input.
I'm rebuilding an 82 turbo motor and want to replace the clutch before I put it back in. I've read about using a stock Daikin or Exedy clutch kit with a "heavy duty" pressure plate. This sounds good to me because I don't want a super stiff pedal but I don't want slippage either. Does anyone know a specific model or part number for this pressure plate? I have a 240mm turbo flywheel and hope to eventually have around 250-300 hp daily driver without much racing.
So last weekend I tried to istall my standard size Sealed Power Piston Rings. TOO MUCH GAP. So I ordered 50mm oversized ones, and when I was filing the last of the second rings it broke. I want to scream. Does anyone know where I can buy just one cylinder 50mm oversized Sealed Power Ring set. I don't want to spend money on a whole nother set.
It says this can be for a 280zx turbo with manual transmission, but I'm skepticla because I thought that was a higher volume pump than the other Zs listed. It's a good price though, sounds too good to be true. Anyone know? http://cgi.ebay.com/ebaymotors/Nissan-Datsun-200SX-240Z-260Z-280Z-ZX-Turbo-Oil-PUMP_W0QQcmdZViewItemQQcategoryZ6778QQitemZ7992895550QQrdZ1QQsspagenameZWDVW
How bout this one? Is it a lot louder than the oval one? A whole lot louder? I think it is part #17296? http://cgi.ebay.com/ebaymotors/Race-muffler-Dynomax-Ultra-Flow-BRAND-NEW_W0QQcmdZViewItemQQcategoryZ33636QQitemZ7991045525QQrdZ1
Is there anything wrong with a turbo oil pump form victoria british? I was looking at my catologue the other day and I think they were less than $70. That seems like a pretty good deal, especially since I need to make an order from them soon anyway.
I'm planning to get the MSA dp for my turbo and then go 3" exhaust into a Dynomax Ultraflo muffler. I know these have been discussed a lot and I have read a lot about them. Everyone talks about them being quiet. This is my daily driver (77 280z, 82 turbo engine) so I don't want it too loud, but I want it to sound modified. So I don't mind if it's pretty loud. So which ultraflo fits well in the 280z and isn't too quiet?
HAs anyone tried this ebay clutch? How much power can it handle? http://cgi.ebay.com/ebaymotors/Extreme-Clutch-Kit-81-83-280ZX-Turbo-84-89-300ZX_W0QQcmdZViewItemQQcategoryZ33730QQitemZ7978558590QQrdZ1
There is a bead blaster where I am working this summer, and I am wondering what all I should blast while my engine is dissasembled. I don't know what can be damaged and what can handle it. The block and head are already cleaned, but can I do the pistons, manifolds, or anything else?
I was wondering if this electric fan would leave room between the stock radiator and the motor (dizzy in particular) to run 2.5" ic piping. It says the fan pulls 3300 cfm which sounds like more than enough. The zirgo.com site is down right now but I believe it said the fan was 3.25" thick.
I think this is one of the best looking z's I've seen and I'm about to paint my car and want to know if a paint job like this would cost more than a good crimson paint job. Do the materials that make this dark silver look so shiny cost a lot more than it would cost to make a crimson shiny. I know it's kind of a strange question, but this car looks so much better than some dark silver cars dI've seen. It's the one about half way down the page in the grass with the hood open. http://www.cardomain.com/ride/396705 maybe it's just the lighting cause I know that's a big deal, but I was just curious cause the dark silver car on the front of a recent VB catologue doesn't look nearly that good.
Well I'm doing a turbo swap and getting the body on my 77 painted all at the same time. Of corse I'm running out of money. I want a paint job that looks good and lasts a long time, but not show car. I've heard that the most expensive part is prep work and I'm wondering how much of it I can practically do. The car has a pretty big dent in the passenger fender. It has a slite ripple down each side where I think molding used to be. Its got rust under the battery, a rusted out passenger floorboard, rust along the bottom of the doors (rusted through on the body nothing on the doors themselves), and some rust along the back where the lights and bumper go. I've already got everything off. And its got a really bad paint job on it. So I'll probably need to do a lot of sanding. How realistic would it be for me to do the prep, body work. After buying materials (sander, bondo, etc) would I save much. I've never done this before, but I'm pretty artistic and can learn pretty fast. I hope y'all can advise me in this. Thanks a lot.
Well I'm planning to run megasquirt so I don't THINK I need to vent back and I like the sound. I've heard people say that about every aftermarket bov leaks (except HKS, don't want to spend that much) so which is really the best. I would like it kinda loud, but also reliable. Would this be Greddy S, Blitz DD, TurboXS H, others?
Hey guys I can't figure out if this is the Blitz BOV that people get? Thanks http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4558524656&category=107063
I'm doing a turbo swap into my 77 5spd and need advice on what else to buy. I'm looking for about 300rwhp and it's a daily driver. Here's my plan so far already have: 82 zxt engine(doing rebuild, got the head worked, keeping stock pistons) jsk fuel rail 440cc supra injectors (going to have cleaned) need: larg i/c (ebay) fpr(need advice there, what specs am I looking for) t3/t04e 50(57) trim K&N intake 2.5" piping 3" exhaust custom dp autometer boost gauge 240sx tb fuel pump(do I need walbro 255lph or can I go with MSD 43gph for cheaper) turboxs H bov non egr intake and hopefully MSnS I guess I'll be running around 15psi boost to get 300hp but I'm not sure. Does this sound good and is there anything else I need? I've searched a lot and I think this is it but better safe than sorry. Is there anything I need to replace while the engine is apart and what do I need for the fpr and fuel pump. Thanks a lot.
I'm just wondering if it's possible or practical to buy a full To4b or To4e and swap the exhaust housing with the stock t3 exhaust housing to make a hybrid. This may have already been addressed but I couldn't find it. You probably can't or I would have heard more about it but I thought I'd ask since sometimes they are cheaper than hybrids. Thanks guys.
Hey guys, just wondering if anyone has ever tried a turbo from this guy and if they are quality or if they are along the lines of XS Power. THANKS. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7978590685&category=33742
This is a strange question but I've got to go pick up an 82 280zx turbo this weekend that has dry rotted tires. I was just wondering if I could take two of the wheels off of my 77 280z just to towe it with a dolly for 90 miles? They aren't stock I don't think, but they are 14" and they don't stick out any. THANKS.
Thanks guys. I knew yall would know. I'll hold off. Glad I didn't waste the money.
Hi I'm trying to collect parts for my turbo swap this summer and I'm just curious if there's any reason no to bid on this turbo? It seems pretty cheap and that's why I'm so skeptical. Thanks. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4542927152&sspagename=STRK%3AMEWA%3AIT
eibach springs for 280z
jmark06 replied to jmark06's topic in Brakes, Wheels, Suspension and Chassis
Thanks so much Jersey, I don't know how I missed those, I scan Ebay all the time.... I've been on this site for a long time and am well aware of the search function as I have used it many times. The springs I am looking for have been discontinued and I have already tried ordering them from three different vendors. That's why I was asking the question, not because I was looking for a freebie answer.
