Well, I replaced the fuel pump today with a known working one.  Same results.  Fuel pressure takes awhile to build up.  Have to crank the engine over for a good while.  Once the pressure gauge hits around 20psi the engine will start.  From there it SLOWLY raises to about 26ish psi.  If I try to give it any more throttle (other than idleing) it will bog and "POP".  After running for a little bit (under 1 minute) it will start to lose psi and end up dieing out.
I tried pinching the return line with hose pliers.  I was able to get the fuel pressure to increase, but it VERY SLOWLY raised to around 26-28psi, but never higher.  Eventually it will go back to sputtering and will die out after the fuel pressure drops again.
So, I guess I can rule out the fuel pump to be the cause?  Now I'm leaning towards the FPR?  Any other suggestions or things to check would be greatly appreciated.
