Search the Community
Showing results for tags 'brake lights'.
1978 280z: When I hit my brakes my side marker lights and dash backlight come on. I haven't had the car very long so not sure if it's always been like this but I just started noticing it. Any ideas?
- 3 replies
- Brakes
- side lights
(and 3 more)
Tagged with:
So I can't seem to figure out this electrical problem. My turn signal switch worked for a while and then stopped working. Park lights still work when the headlights are turned on and hazard lights work, The brake lights worked for a while but recently stopped working as well (not sure if caused by turn signal problem) So I tried cleaning the connections by following this write up: http://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/ and after they still don't work. So i borrowed a turn signal from another 72' 240z and still nothing so it has to be before the switch. Haven't had the chance to follow the wire and i'm not really looking forward to dealing with electrical since i just fixed an alternator problem which was a headache. Any input is appreciated.
- 1 reply
- Electrical
- Lights
(and 5 more)
Tagged with:
Good Evening, 1978 280z My right brake light is acting up. The bulb is ok, and it will illuminate when the lights are on, but will not illuminate due to the brake pedal action. The left light is completely fine. Ex: If lights are on, the right brake light will be illuminated on the dull setting but not increase light intensity when the brakes are applied. Not sure where to begin looking or what wire could be the issue. Tried to look at wiring diagrams but not really sure where to begin with that. Any help would be much appreciated. Thanks!
- 3 replies
- Bulb
- Brake Lights
(and 2 more)
Tagged with:
