Search the Community
Showing results for tags 'dry ice'.
Removing undercoating is usually one of most labor intense jobs when restoring a vehicle. So when I heard about using dry ice to remove undercoating, I decided to try it. Dry Ice is usually found at industrial welding stores. The price runs from $2.00 to $3.00 per pound. When using dry ice, gloves and safety glasses worn to prevent frostbite. First, I tried using dry ice right from the package and just laid the block on the undercoating. The undercoating got to 15 degrees but didn't really remove large chunks of undercoating. So I tried the next method- put the dry ice in a 5 gallon plastic bucket and smash it till it resembles snow. Then I poured alcohol-92% (bought from CVS) into the bucket and mixed it till it was mud like. I checked the temperature and it was minus 15 degrees. I packed the mixture on to the undercoating( packing snow). After couple of minutes, undercoating made a cracking sound. The undercoating was so frozen, it cracked. Now all you have to do is to hit the undercoating with a hammer. The undercoating came off in small to large chucks. Inspecting the area shoes that there was hardly any undercoating remaining( came off very cleanly). I worked a small area 12" x12" at a time to get the most of the dry ice-kept moving the ice around slowly. I used about 15 pounds of dry ice and two bottle of alcohol to do the interior floor of the car. Haven't tried this procedure on the undercoating on the bottom of the car yet. Building the rotisserie now. Sunny [sharedmedia=videos:videos:297]
From the album: datsnz
dry ice with alcohol was very effective for undercoating removal.
