Hi,
I'm planning to add a MAP sensor to my current setup; this includes 3.1L + Triple Webers + Electromotive HPX ignition. If you take a look at the attached photos, you'll see how I plumbed PCV and the brake booster. I've read that it's not advisbile to pull vacuum for a MAP sensor directly off the same vacuum line as the booster. My DCOE 40-151's have a vacuum port that I use to balance the carbs using gauges. Would this be a sufficient vacuum source for a 1 bar map sensor?
Thanks,
Bajcsi
